Home » Eclipse Projects » Eclipse Platform » Specifying clean target to headless PDE build
Specifying clean target to headless PDE build [message #323452] Thu, 20 December 2007 18:09 Go to next message
Originally posted by: vgrishchenko.serena.com
Howdy,
Is this legal to pass -Dtarget=clean to a headless PDE build invoked via
antRunner?
java -jar " path_to_org.eclipse.equinox.launcher_1.0.1.R33x_v20070828.ja r "
-application org.eclipse.ant.core.antRunner
-buildfile
" path_to_org.eclipse.pde.build_3.3.2.R331_v20071019\scripts\b uild.xml "
-Dtarget=clean -Dbuilder="build_config_folder"
I'm getting this error message:
D:\Temp\build_test\allElements.xml:12: The following error occurred while
executing this line:
Target "clean" does not exist in the project "Generic Build Targets".
Looking at the build files the clean target in build.xml attempts to set
property named "target" to value "cleanElements" which is the target to be
invoked in generic targets, this fails as "target" is already set from the
command line to "clean" and thus get the above error.
Thanks for any input,
V.
Re: Specifying clean target to headless PDE build [message #323499 is a reply to message #323452] Sat, 22 December 2007 17:48 Go to previous messageGo to next message
Try the following :
....\build.xml" clean,main -Dbuilder="build_config_folder"
Snjeza
Vladimir G. wrote:
> Howdy,
> antRunner?
> -buildfile
> while executing this line:
> be invoked in generic targets, this fails as "target" is already set
> from the command line to "clean" and thus get the above error.
> V.
Re: Specifying clean target to headless PDE build [message #323761 is a reply to message #323452] Mon, 07 January 2008 15:57 Go to previous message
The main build.xml for pdeBuild calls targets in the genericTargets.xml through
the allElements.xml. The target parameter is used to specify the target to run,
and the value needs to be a target that is present in genericTargets.xml script.
Vladimir G. wrote:
> Howdy,
> antRunner?
> -buildfile
> V.
Previous Topic:Include multiple features in build output
Next Topic:Invalid project description error message returned when importing projects.
Current Time: Thu Jul 24 18:43:30 EDT 2025
Powered by FUDForum. Page generated in 0.03362 seconds
