Landmarked files wont display in navigator pane [message #32695] |
Tue, 09 October 2007 00:48  |
Originally posted by: nojunk.hotmail.com
When I activate a task and add a file to it as a landmark, it doesn't
appear in the navigator pane when I focus on active task but it does in
the package explorer.
I normally use navigator so this is really annoying. Sometimes I can see
base directories but I have removed some of these as the contain no
selectable files. All I can see is the top level base directory.
What's up? Is this normal behaviour?
Hugh
Re: Landmarked files wont display in navigator pane [message #36257 is a reply to message #35985] |
Sun, 11 November 2007 18:37  |
Okay, I finally installed the weekly build version by adding the
directory to the software updates (doh soz) and the problems seem to
have disappeared ( Yay!! it's working for the first time =) ). Thankyou
very much because I like it very much.
The only thing I noticed was that it doesn't seem to initialise anything
the first time I activate a task after starting eclipse. I need to
deactivate the task and reactivate it before the context is loaded, but
only after I run eclipse up with no task activated and then select a
task. Also the navigator pane filter is not enabled first time even when
I have a task activated. This happens only after I select a file.
Hugh
Mik Kersten wrote:
> Sounds strange. Could you please make sure that you have the latest
> weekly build, and then file a bug with steps to reproduce? Please
> include the kinds of elements that you are clicking and the exact names
> of the views that you are referring to.
> http://www.eclipse.org/mylyn/downloads/
> Mik
> HJB wrote:
>> Actually this isn't fixed at all. I've been trying to see what the
>> problem is and it relates to subclipse. For some reason everything
>> works normally except with subversion controlled files. I've been on
>> the subclipse site trying to see if they have any input but sadly they
>> haven't said anything. I suppose it's not their problem but it may
>> have anything to do with ignoring .svn directories or svn:ignore
>> patterns. Anyway, I don;t know what further to do with it now.
>> Hugh
>> Mik Kersten wrote:
>>> Hugh, I assume that this is now resolved given interaction on the bug
>>> you filed.
>>> Mik
>>>> doesn't appear in the navigator pane when I focus on active task but
>>>> it does in the package explorer.
>>>> see base directories but I have removed some of these as the contain
>>>> no selectable files. All I can see is the top level base directory.
>>>> Hugh
Re: Landmarked files wont display in navigator pane [message #583344 is a reply to message #32695] |
Fri, 12 October 2007 00:28  |
you filed.
Mik
> Hugh
Re: Landmarked files wont display in navigator pane [message #584591 is a reply to message #32923] |
Thu, 08 November 2007 01:37  |
problem is and it relates to subclipse. For some reason everything works
normally except with subversion controlled files. I've been on the
haven't said anything. I suppose it's not their problem but it may have
anything to do with ignoring .svn directories or svn:ignore patterns.
Hugh
> you filed.
> Mik
>> Hugh
Re: Landmarked files wont display in navigator pane [message #584622 is a reply to message #35916] |
Thu, 08 November 2007 19:35  |
Mik
> Hugh
>> you filed.
>> Mik
>>> Hugh
Re: Landmarked files wont display in navigator pane [message #584680 is a reply to message #35985] |
Fri, 09 November 2007 00:57  |
I have reopened the old bug I started.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=204635
There are no error messages and it only occurs in the navigator view.
It occurs for all/any resource which is in svn control but if any
resources in the same task are outside svn they work fine.
Hugh
> Mik
>> Hugh
>>> you filed.
>>> Mik
>>>> Hugh
Re: Landmarked files wont display in navigator pane [message #584757 is a reply to message #35985] |
Hugh
> Mik
>> Hugh
>>> you filed.
>>> Mik
>>>> Hugh
FUDForum. Page generated in 1.05936 seconds
