Home » Eclipse Projects » Mylyn » Landmarked files wont display in navigator pane
Landmarked files wont display in navigator pane [message #32695] Tue, 09 October 2007 00:48 Go to next message
Originally posted by: nojunk.hotmail.com
When I activate a task and add a file to it as a landmark, it doesn't
appear in the navigator pane when I focus on active task but it does in
the package explorer.
I normally use navigator so this is really annoying. Sometimes I can see
base directories but I have removed some of these as the contain no
selectable files. All I can see is the top level base directory.
What's up? Is this normal behaviour?
Hugh
Re: Landmarked files wont display in navigator pane [message #32923 is a reply to message #32695] Fri, 12 October 2007 00:28 Go to previous messageGo to next message
Originally posted by: beatmik.acm.org
Hugh, I assume that this is now resolved given interaction on the bug
you filed.
Mik
> Hugh
Re: Landmarked files wont display in navigator pane [message #35916 is a reply to message #32923] Thu, 08 November 2007 01:37 Go to previous messageGo to next message
Actually this isn't fixed at all. I've been trying to see what the
problem is and it relates to subclipse. For some reason everything works
normally except with subversion controlled files. I've been on the
subclipse site trying to see if they have any input but sadly they
haven't said anything. I suppose it's not their problem but it may have
anything to do with ignoring .svn directories or svn:ignore patterns.
Anyway, I don;t know what further to do with it now.
Hugh
> you filed.
> Mik
>> in the package explorer.
>> see base directories but I have removed some of these as the contain
>> no selectable files. All I can see is the top level base directory.
>> Hugh
Re: Landmarked files wont display in navigator pane [message #35985 is a reply to message #35916] Thu, 08 November 2007 19:35 Go to previous messageGo to next message
Sounds strange. Could you please make sure that you have the latest
weekly build, and then file a bug with steps to reproduce? Please
include the kinds of elements that you are clicking and the exact names
of the views that you are referring to.
http://www.eclipse.org/mylyn/downloads/
Mik
> Hugh
>> you filed.
>> Mik
>>> Hugh
Re: Landmarked files wont display in navigator pane [message #36119 is a reply to message #35985] Fri, 09 November 2007 00:57 Go to previous messageGo to next message
I have reopened the old bug I started.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=204635
There are no error messages and it only occurs in the navigator view.
It occurs for all/any resource which is in svn control but if any
resources in the same task are outside svn they work fine.
Hugh
> Mik
>> works normally except with subversion controlled files. I've been on
>> the subclipse site trying to see if they have any input but sadly they
>> have anything to do with ignoring .svn directories or svn:ignore
>> patterns. Anyway, I don;t know what further to do with it now.
>> Hugh
>>> you filed.
>>> Mik
>>>> doesn't appear in the navigator pane when I focus on active task but
>>>> it does in the package explorer.
>>>> Hugh
Re: Landmarked files wont display in navigator pane [message #36153 is a reply to message #35985] Fri, 09 November 2007 01:17 Go to previous messageGo to next message
BTW, when I put the 7 files from
http://download.eclipse.org/tools/mylyn/update/weekly/e3.3/ into my
eclipse\plugin directory the navigator view task filter stays disabled
until I add a resource outside svn and the problem now occurs in the
package explorer too.
If I disable the filter and open up the tree in Navigator I can see the
file marked as a landmark, but as soon as I enable the filter it
disappears again.
Re: Landmarked files wont display in navigator pane [message #36257 is a reply to message #35985] Sun, 11 November 2007 18:37 Go to previous message
Okay, I finally installed the weekly build version by adding the
directory to the software updates (doh soz) and the problems seem to
have disappeared ( Yay!! it's working for the first time =) ). Thankyou
very much because I like it very much.
The only thing I noticed was that it doesn't seem to initialise anything
the first time I activate a task after starting eclipse. I need to
deactivate the task and reactivate it before the context is loaded, but
only after I run eclipse up with no task activated and then select a
task. Also the navigator pane filter is not enabled first time even when
I have a task activated. This happens only after I select a file.
Hugh
> Mik
>> Hugh
>>> you filed.
>>> Mik
>>>> Hugh
Re: Landmarked files wont display in navigator pane [message #583344 is a reply to message #32695] Fri, 12 October 2007 00:28 Go to previous message
you filed.
Mik
> Hugh
Re: Landmarked files wont display in navigator pane [message #584591 is a reply to message #32923] Thu, 08 November 2007 01:37 Go to previous message
Hugh
> you filed.
> Mik
>> Hugh
Re: Landmarked files wont display in navigator pane [message #584622 is a reply to message #35916] Thu, 08 November 2007 19:35 Go to previous message
Mik
> Hugh
>> you filed.
>> Mik
>>> Hugh
Re: Landmarked files wont display in navigator pane [message #584680 is a reply to message #35985] Fri, 09 November 2007 00:57 Go to previous message
Hugh
> Mik
>> Hugh
>>> you filed.
>>> Mik
>>>> Hugh
Re: Landmarked files wont display in navigator pane [message #584701 is a reply to message #35985] Fri, 09 November 2007 01:17 Go to previous message
disappears again.
Re: Landmarked files wont display in navigator pane [message #584757 is a reply to message #35985] Sun, 11 November 2007 18:37 Go to previous message
Hugh
> Mik
>> Hugh
>>> you filed.
>>> Mik
>>>> Hugh
Previous Topic:Deleted resources not added to the active change set
Next Topic:JIRA connector for 2.0.0 on Eclipse 3.2 won't install
Current Time: Tue Jul 22 12:09:09 EDT 2025
Powered by FUDForum. Page generated in 0.10310 seconds
