Eclipse Europa hangs often [message #323012] |
Wed, 05 December 2007 01:28  |
I have been having a serious recurring problem with Eclipse since I
started using Europa.
The problem is that the IDE hangs quite often. When it hangs, it uses all
available CPU. The trigger for the hang could be anything: requesting
annotations on a file, opening a file, switching to a different
perspective. I can't say that I've found a pattern to the triggers. I need
to kill the process and restart (which I need to do sometimes more than
once an hour!).
I've tried increasing the amount of memory available to the VM I'm running
in. I've also looked in the log file which is created by default and not
found any indication of why it is hanging. I haven't been able to find any
similar bug reports.
I'm using version Version: 3.3.1.1 (Build id: M20071023-1652) running on
Fedora Core release 6 with Java 1.5.0_08.
Any suggestions for things I could check or do to prevent these hangs
would be very much appreciated!
David
Re: Eclipse Europa hangs often [message #323025 is a reply to message #323012] |
Wed, 05 December 2007 07:38   |
--------------000203050300010909060205
David,
Have a look at
http://wiki.eclipse.org/index.php/How_to_report_a_deadlock
I know what you describe doesn't sound like a deadlock, but this
approach would help determine what the process is doing and that might
help...
David Resnick wrote:
> all available CPU. The trigger for the hang could be anything:
> requesting annotations on a file, opening a file, switching to a
> different perspective. I can't say that I've found a pattern to the
> triggers. I need to kill the process and restart (which I need to do
> sometimes more than once an hour!).
> running in. I've also looked in the log file which is created by
> default and not found any indication of why it is hanging. I haven't
> been able to find any similar bug reports.
> on Fedora Core release 6 with Java 1.5.0_08.
> David
<html>
<head>
http-equiv="Content-Type">
</head>
David,<br>
<br>
Have a look at <br>
<blockquote><a
href="http://wiki.eclipse.org/index.php/How_to_report_a_deadlock">http://wiki.eclipse.org/index.php/How_to_report_a_deadlock</a><br>
</blockquote>
help...<br>
<br>
<br>
<blockquote
cite="mid:03a3b392293920bef8b2e642b16b0777$1@www.eclipse.org"
type="cite">Hi,
<br>
<br>
started using Europa. <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
David
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------000203050300010909060205--
FUDForum. Page generated in 0.03528 seconds
