Home » Language IDEs » AspectJ » Problems using AJDT v1.1.4 with Eclipse 3.0 M7
Problems using AJDT v1.1.4 with Eclipse 3.0 M7 [message #32664] Thu, 08 April 2004 19:26 Go to next message
I installed AJDT version 1.1.4 using the live update feature. I am
having two serious problems
- I was given a prompt asking me if I wanted to make AspectJ editor the
default for .java files. I selected yes. However I cannot save any
modifications to .java files using the AspectJ/Java editor. The
following exception is stored in the log file
!ENTRY org.eclipse.ui 2 0 Apr 08, 2004 19:00:02.476
!MESSAGE Save Failed
!STACK 0
java.lang.NoSuchMethodError:
org.eclipse.ui.texteditor.AbstractTextEditor.createSaveOpera tion(Z)Lorg/eclipse/ui/actions/WorkspaceModifyOperation;
org.eclipse.ajdt.internal.ui.editor.AspectJEditor.doSave(Asp ectJEditor.java:132)
at org.eclipse.ui.internal.EditorManager$10.run(EditorManager.j ava:1015)
at org.eclipse.ui.internal.EditorManager$8.run(EditorManager.ja va:870)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:302)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:252)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:550)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:547)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:1644)
org.eclipse.ui.internal.EditorManager.runProgressMonitorOper ation(EditorManager.java:876)
at org.eclipse.ui.internal.EditorManager.savePart(EditorManager .java:1020)
at org.eclipse.ui.internal.WorkbenchPage.savePart(WorkbenchPage .java:2420)
org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPa ge.java:2432)
at org.eclipse.ui.internal.SaveAction.run(SaveAction.java:72)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.ui.internal.commands.ActionHandler.execute(Actio nHandler.java:40)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:427)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:815)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:856)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:526)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$2(Work benchKeyboard.java:458)
org.eclipse.ui.internal.keys.WorkbenchKeyboard$1.handleEvent (WorkbenchKeyboard.java:241)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:699 )
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:832)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:857)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Control.sendKeyEvent(Control.java:17 16)
at org.eclipse.swt.widgets.Control.sendKeyEvent(Control.java:17 12)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:3037)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:2940 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:2873 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:13 71)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2027)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1550)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1526)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:265)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:257)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:104)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
- I wrote a simple HelloWorld java program:
public class Test {
System.out.println("test");
that does not compile in an AspectJ project. If I select
Project->Rebuild Project the following exception is thrown:
!ENTRY org.eclipse.ajdt.ui 4 0 Apr 08, 2004 19:24:07.674
!MESSAGE Compile error, caught Throwable: java.lang.NoSuchMethodError:
org.eclipse.ui.internal.WorkbenchPlugin.getPluginWorkspace() Lorg/eclipse/core/resources/IWorkspace;
!STACK 0
org.eclipse.ajdt.internal.ui.ajde.ProjectProperties.getOutpu tPath(ProjectProperties.java:84)
org.aspectj.ajde.internal.AspectJBuildManager$CompilerThread .getFormattedOptionsString(AspectJBuildManager.java:186)
org.aspectj.ajde.internal.AspectJBuildManager$CompilerThread .run(AspectJBuildManager.java:162)
If on the other hand I right-click the project in the Package Explorer
view and select Remove AspectJ Nature the project runs fine.
Does anyone have any idea of what might be wrong?
Omair
Re: Problems using AJDT v1.1.4 with Eclipse 3.0 M7 [message #32701 is a reply to message #32664] Fri, 09 April 2004 03:54 Go to previous messageGo to next message
Originally posted by: newsserver_mails.bodden.de
1.1.4 for never targeted for any builds later than M4. Take 1.1.6 (still
dev) instead.
Eric
Eric Bodden
ICQ UIN: 12656220
Website: http://www.bodden.de
GPG: BB465582
Thanks: Uninstall procedure for 1.1.4? (if applic) [message #32733 is a reply to message #32701] Fri, 09 April 2004 11:28 Go to previous message
> dev) instead.
> Eric
Is there an uninstall procedure that I should follow to remove 1.1.4
before I attempt to install 1.1.6.
So I'm assuming that the procedure to install 1.1.6 is to select the
update site as http://download.eclipse.org/technology/ajdt/dev/update
Is that right?
Omair
Re: Problems using AJDT v1.1.4 with Eclipse 3.0 M7 [message #577101 is a reply to message #32664] Fri, 09 April 2004 03:54 Go to previous message
dev) instead.
Eric
Eric Bodden
ICQ UIN: 12656220
GPG: BB465582
Thanks: Uninstall procedure for 1.1.4? (if applic) [message #577109 is a reply to message #32701] Fri, 09 April 2004 11:28 Go to previous message
> dev) instead.
> Eric
Is that right?
Omair
Previous Topic:Problems using AJDT v1.1.4 with Eclipse 3.0 M7
Next Topic:Is AJDT 1.1.6 compatible with Eclipse 3.0 M8?
Current Time: Sat May 10 23:21:47 EDT 2025
Powered by FUDForum. Page generated in 0.03286 seconds
