Problems using AJDT v1.1.4 with Eclipse 3.0 M7 [message #32664] |
Thu, 08 April 2004 19:26  |
I installed AJDT version 1.1.4 using the live update feature. I am
having two serious problems
- I was given a prompt asking me if I wanted to make AspectJ editor the
default for .java files. I selected yes. However I cannot save any
modifications to .java files using the AspectJ/Java editor. The
following exception is stored in the log file
!ENTRY org.eclipse.ui 2 0 Apr 08, 2004 19:00:02.476
!MESSAGE Save Failed
!STACK 0
java.lang.NoSuchMethodError:
org.eclipse.ui.texteditor.AbstractTextEditor.createSaveOpera tion(Z)Lorg/eclipse/ui/actions/WorkspaceModifyOperation;
org.eclipse.ajdt.internal.ui.editor.AspectJEditor.doSave(Asp ectJEditor.java:132)
at org.eclipse.ui.internal.EditorManager$10.run(EditorManager.j ava:1015)
at org.eclipse.ui.internal.EditorManager$8.run(EditorManager.ja va:870)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:302)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:252)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:550)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:547)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:1644)
org.eclipse.ui.internal.EditorManager.runProgressMonitorOper ation(EditorManager.java:876)
at org.eclipse.ui.internal.EditorManager.savePart(EditorManager .java:1020)
at org.eclipse.ui.internal.WorkbenchPage.savePart(WorkbenchPage .java:2420)
org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPa ge.java:2432)
at org.eclipse.ui.internal.SaveAction.run(SaveAction.java:72)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.ui.internal.commands.ActionHandler.execute(Actio nHandler.java:40)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:427)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:815)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:856)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:526)
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$2(Work benchKeyboard.java:458)
org.eclipse.ui.internal.keys.WorkbenchKeyboard$1.handleEvent (WorkbenchKeyboard.java:241)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:699 )
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:832)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:857)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Control.sendKeyEvent(Control.java:17 16)
at org.eclipse.swt.widgets.Control.sendKeyEvent(Control.java:17 12)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:3037)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:2940 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:2873 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:13 71)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2027)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1550)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1526)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:265)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:257)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:104)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
- I wrote a simple HelloWorld java program:
public class Test {
System.out.println("test");
that does not compile in an AspectJ project. If I select
Project->Rebuild Project the following exception is thrown:
!ENTRY org.eclipse.ajdt.ui 4 0 Apr 08, 2004 19:24:07.674
!MESSAGE Compile error, caught Throwable: java.lang.NoSuchMethodError:
org.eclipse.ui.internal.WorkbenchPlugin.getPluginWorkspace() Lorg/eclipse/core/resources/IWorkspace;
!STACK 0
org.eclipse.ajdt.internal.ui.ajde.ProjectProperties.getOutpu tPath(ProjectProperties.java:84)
org.aspectj.ajde.internal.AspectJBuildManager$CompilerThread .getFormattedOptionsString(AspectJBuildManager.java:186)
org.aspectj.ajde.internal.AspectJBuildManager$CompilerThread .run(AspectJBuildManager.java:162)
If on the other hand I right-click the project in the Package Explorer
view and select Remove AspectJ Nature the project runs fine.
Does anyone have any idea of what might be wrong?
Omair
FUDForum. Page generated in 0.05670 seconds
