Home » Eclipse Projects » Eclipse Platform » [editor] Exception when opening editor using the navigate action
[editor] Exception when opening editor using the navigate action [message #322757] Wed, 28 November 2007 04:39 Go to next message
Originally posted by: valere.fedronic.ext.streamezzo.com
I have detected a bug with the navigation.
*Description* :
After using the back action (alt+left) the editors failed to open (an
error dialog pops' up), and then editor area displays this stack trace :
org.eclipse.core.runtime.CoreException: The file does not exist.
org.eclipse.core.internal.filebuffers.ResourceFileBuffer.cre ate(ResourceFileBuffer.java:237)
org.eclipse.core.internal.filebuffers.TextFileBufferManager. connect(TextFileBufferManager.java:109)
org.eclipse.ui.editors.text.TextFileDocumentProvider.createF ileInfo(TextFileDocumentProvider.java:552)
org.eclipse.ui.internal.NavigationHistoryEntry.restoreLocati on(NavigationHistoryEntry.java:66)
org.eclipse.ui.internal.NavigationHistory.gotoEntry(Navigati onHistory.java:452)
org.eclipse.ui.internal.NavigationHistory.shiftEntry(Navigat ionHistory.java:517)
org.eclipse.ui.internal.NavigationHistory.backward(Navigatio nHistory.java:501)
*Step to reproduce*
1) Open a new project
2) Create a new File
3) Open the file
4) Close the file
5) Delete the project (+delete content)
6) Click on the 'navigate back' button (alt+left)
*Expected*
The editor should use the 'status control' (StatusTextEditor) to display
the error message.
Should i report this? or is it known?
Reproducible with eclipse 3.3 to 3.4M3
Valère.
Re: [editor] Exception when opening editor using the navigate action [message #322761 is a reply to message #322757] Wed, 28 November 2007 07:09 Go to previous messageGo to next message
valere fedronic wrote:
> *Description* :
> at
> at
> at
> at
> at
> at
> at
> *Step to reproduce*
> 3) Open the file
> 4) Close the file
> *Expected*
> display the error message.
Yes, you should report it against Platform UI using bugzilla.
Dani
> or is it known?
> Valère.
Re: [editor] Exception when opening editor using the navigate action [message #322762 is a reply to message #322761] Wed, 28 November 2007 07:38 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=211204
Valère.
>> *Description* :
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> *Step to reproduce*
>> 3) Open the file
>> 4) Close the file
>> *Expected*
> Dani
>> or is it known?
>> Valère.
Previous Topic:NPE calling log() from my contributed Ant task
Next Topic:Eclipse and Theme Support
Current Time: Mon Jul 14 08:30:50 EDT 2025
Powered by FUDForum. Page generated in 0.03810 seconds
