Home » Language IDEs » C / C++ IDE (CDT) » Rebind C-f in LPEX
Rebind C-f in LPEX [message #32639] Fri, 17 May 2002 06:32 Go to next message
Originally posted by: herbert.spamcop.net
I like the vi keymap for LPEX, however the search dialogue on
C-f really irritates me. How can I reconfigure this to PageDown,
like vi's fathers wanted it?
Herbert
WE ARE THE BORG - RESISTANCE IS VOLTAGE DIVIDED BY CURRENT!
Dipl.Ing. Martin "Herbert" Dietze -=-=- The University of Buckingham -=-=-
Re: Rebind C-f in LPEX [message #32674 is a reply to message #32639] Fri, 17 May 2002 08:42 Go to previous messageGo to next message
Originally posted by: adrianstoristeanu.sympatico.ca
Unfortunately, the vi base profile in LPEX is not (because its
implementation had to be different from the generic LPEX key
redefinition mechanism that could be used for other base profiles)
user-customizable...
There are '/' and '?' activating string search (forwards and backwards)
in the vi mode, but the vi documentation I know of doesn't say pageDown
should search. Should it?
Herbert Martin Dietze wrote:
> Hello,
> Cheers,
> Herbert
Re: Rebind C-f in LPEX [message #32740 is a reply to message #32674] Fri, 17 May 2002 08:53 Go to previous messageGo to next message
You *could* redefine pageDown in the command-line context (Preferences
-> LPEX Editor -> User Key Actions -> Key: pageDown.c Action:
findAndReplace -> Set -> OK): now, '/' or '?' will take you to the
command line, and pageDown will bring up the live find. The extra step
is, however a hassle, methinks...
> > Hello,
> > Cheers,
> > Herbert
Re: Rebind C-f in LPEX [message #32814 is a reply to message #32674] Fri, 17 May 2002 10:22 Go to previous messageGo to next message
adrian <adrianstoristeanu@sympatico.ca> wrote:
[quoting fixed]
Oops, that's a misunderstanding. C-f should do PageDown, not
Search.
Herbert
Tand, Tand ist das Gebilde von Menschenhand
Re: Rebind C-f in LPEX [message #32832 is a reply to message #32740] Fri, 17 May 2002 10:26 Go to previous messageGo to next message
command-line context?
I did not succeed to get anything but `find' assigned to C-f.
BTW, I remember LPEX from my good old OS/2 days (I even wrote a
WordStar emulation for it), and there was keymap files you
could edit by hand. So this has changed for this particular
implementation?
Herbert
If you cannot convince them, confuse them.
-- Harry S Truman
Re: Rebind C-f in LPEX [message #32935 is a reply to message #32832] Fri, 17 May 2002 10:39 Go to previous messageGo to next message
A key can behave differently (be bound to a different action) depending
on its context (see the keyAction parameter in the docs): when in the
text-area (once again, excepting the vi base profile...), when in the
prefix area (for profiles such as xedit), and when on the LPEX command
line.
> implementation?
Key-action bindings can be done on the fly for the current view from the
LPEX command line:
keyAction.tab insertTab
Default key definitions are done via the Preferences, and are stored in
eclipse/workspace/.metadata/.plugins/com.ibm.lpex/Editor.pro perties
(which you could edit manually), e.g.,
default.updateProfile.userKeyActions="tab insertTab pageDown.c
findAndReplace"
which redefines the tab in the text area (the default context, or
explicitly ".t"), and pageDown key on the command line (context is
".c").
Re: Rebind C-f in LPEX [message #32966 is a reply to message #32814] Fri, 17 May 2002 10:44 Go to previous messageGo to next message
In Eclipse, Ctrl+F is the global find action. Therefore, even if it
were redefined in LPEX to do pageDown (or anything else), it won't even
get to LPEX. The Eclipse key-bindings feature may solve some of this,
but I'm not sure what's the current status.
> Search.
Re: Rebind C-f in LPEX [message #32999 is a reply to message #32966] Fri, 17 May 2002 10:51 Go to previous message
As Robert just pointed out to me, C-F and C-B are indeed defined in vi
to page up and down, and this is indeed how they are defined in LPEX's
vi base profile. C-F, though, has the problem indicated below when
running inside Eclipse.
> > Search.
Previous Topic:Use LPEX as default editor for any file type?
Next Topic:Better handling of tabs (how to?)
Current Time: Sun May 11 11:37:59 EDT 2025
Powered by FUDForum. Page generated in 0.04557 seconds
