Home » Eclipse Projects » Mylyn » Deleted resources not added to the active change set
Deleted resources not added to the active change set [message #32590] Fri, 05 October 2007 04:30 Go to next message
Originally posted by: mauro.molinari.cardinis.com
Hello!
Is anyone experiencing the following problem with Mylyn 2.x like me?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=154324
Everytime I delete a resource, the corresponding CVS outgoing change is
added to the "Unassigned" change set, instead of that of the currently
active task, although that bug is marked as fixed :-(
This also happens when I refactor a class, changing its name: the change
corresponding to the creation of the new class is added to the active
change set, while that corresponding to the deletion of the old class is
added to the "Unassigned" change set...
Any suggestion?
Thanks in advance,
Mauro.
Re: Deleted resources not added to the active change set [message #32888 is a reply to message #32590] Fri, 12 October 2007 00:22 Go to previous messageGo to next message
Originally posted by: beatmik.acm.org
This may be a weird interaction with editor management. Let's diagnose
further on bug.
Mik
Mauro Molinari wrote:
> Hello!
> Any suggestion?
> Thanks in advance,
> Mauro.
Re: Deleted resources not added to the active change set [message #33028 is a reply to message #32888] Fri, 12 October 2007 03:33 Go to previous message
> further on bug.
> Mik
Thank you Mik,
I commented on that bug, reporting some tests I did.
Mauro.
Re: Deleted resources not added to the active change set [message #583330 is a reply to message #32590] Fri, 12 October 2007 00:22 Go to previous message
further on bug.
Mik
> Hello!
> Any suggestion?
> Thanks in advance,
> Mauro.
Re: Deleted resources not added to the active change set [message #583403 is a reply to message #32888] Fri, 12 October 2007 03:33 Go to previous message
> further on bug.
> Mik
Thank you Mik,
Mauro.
Previous Topic:How to undo outgoing changes in a bugzilla task?
Next Topic:Landmarked files wont display in navigator pane
Current Time: Fri May 09 12:55:25 EDT 2025
Powered by FUDForum. Page generated in 0.03679 seconds
