Deleted resources not added to the active change set [message #32590] |
Fri, 05 October 2007 04:30  |
Originally posted by: mauro.molinari.cardinis.com
Hello!
Is anyone experiencing the following problem with Mylyn 2.x like me?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=154324
Everytime I delete a resource, the corresponding CVS outgoing change is
added to the "Unassigned" change set, instead of that of the currently
active task, although that bug is marked as fixed :-(
This also happens when I refactor a class, changing its name: the change
corresponding to the creation of the new class is added to the active
change set, while that corresponding to the deletion of the old class is
added to the "Unassigned" change set...
Any suggestion?
Thanks in advance,
Mauro.
Re: Deleted resources not added to the active change set [message #583330 is a reply to message #32590] |
Fri, 12 October 2007 00:22  |
This may be a weird interaction with editor management. Let's diagnose
further on bug.
Mik
Mauro Molinari wrote:
> Hello!
> Any suggestion?
> Thanks in advance,
> Mauro.
FUDForum. Page generated in 0.03564 seconds
