Home » Eclipse Projects » Nebula » Merging two adjacent cells in Grid
Merging two adjacent cells in Grid [message #32570] Fri, 06 April 2007 12:28 Go to next message
All,
Is it possible to merge two (or more) adjacent cells (located in the
same column)? If so, is there an example somewhere I can use?
Many thanks
Ali.
Re: Merging two adjacent cells in Grid [message #32604 is a reply to message #32570] Fri, 06 April 2007 15:15 Go to previous message
Hi Ali,
Currently you can only merge two cells horizontally. You cannot merge
cells vertically.
-Chris
Ali Naddaf wrote:
> All,
> Many thanks
> Ali.
Re: Merging two adjacent cells in Grid [message #580867 is a reply to message #32570] Fri, 06 April 2007 15:15 Go to previous message
Hi Ali,
cells vertically.
-Chris
Ali Naddaf wrote:
> All,
> Many thanks
> Ali.
Previous Topic:Merging two adjacent cells in Grid
Next Topic:Using nebula widgets in a view of eclipse
Current Time: Fri May 09 16:55:15 EDT 2025
Powered by FUDForum. Page generated in 0.03019 seconds
