Merging two adjacent cells in Grid [message #32570] |
Fri, 06 April 2007 12:28  |
All,
Is it possible to merge two (or more) adjacent cells (located in the
same column)? If so, is there an example somewhere I can use?
Many thanks
Ali.
Re: Merging two adjacent cells in Grid [message #32604 is a reply to message #32570] |
Fri, 06 April 2007 15:15  |
Hi Ali,
Currently you can only merge two cells horizontally. You cannot merge
cells vertically.
-Chris
Ali Naddaf wrote:
> All,
> Many thanks
> Ali.
Re: Merging two adjacent cells in Grid [message #580867 is a reply to message #32570] |
Hi Ali,
cells vertically.
-Chris
Ali Naddaf wrote:
> All,
> Many thanks
> Ali.
FUDForum. Page generated in 0.03730 seconds
