Home » Archived » XML Schema Definition (XSD) » NPE in XSDAnnotationItemProvider
NPE in XSDAnnotationItemProvider [message #32560] Fri, 31 October 2003 13:54 Go to next message
------=_NextPart_000_000A_01C39FAE.2B888900
Content-Type: text/plain;
charset="iso-8859-1"
Ed,
Due to a problem with the way were reading in models, we were =
creating XSDAnnotations with null elements. We haven't quite solved =
that yet, but an interesting side effect is a NPE in the =
XSDAnnotationItemProvider. It would seem that the item provider should =
be a bit more fault tolerant as this exception takes down the property =
sheet page and clutters up the log. Here is the stack...
Oct 31, 2003 12:48:08.062 [main|0] ERROR <com.metamatrix.modeler.ui|0> =
at =
org.eclipse.xsd.provider.XSDAnnotationItemProvider.getText(X SDAnnotationI=
temProvider.java:109)
at =
org.eclipse.emf.edit.provider.AdapterFactoryItemDelegator.ge tText(Adapter=
FactoryItemDelegator.java:93)
at =
org.eclipse.emf.edit.provider.ItemPropertyDescriptor$ItemDel egator.getTex=
t(ItemPropertyDescriptor.java:171)
at =
org.eclipse.emf.edit.ui.provider.PropertyDescriptor$1.getTex t(PropertyDes=
criptor.java:140)...
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1264" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; Due to a problem =
with the way=20
were reading in models, we were creating XSDAnnotations with null=20
elements.&nbsp; We haven't quite solved that yet, but an interesting =
side effect=20
is a NPE in the XSDAnnotationItemProvider.&nbsp; It would seem that the =
item=20
provider should be a bit more fault tolerant as this exception takes =
down the=20
property sheet page and clutters up the log.&nbsp; Here is the=20
stack...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<P><FONT face=3DArial size=3D2>Oct 31, 2003 12:48:08.062 [main|0] ERROR=20
&lt;com.metamatrix.modeler.ui|0&gt; =
java.lang.NullPointerException</FONT></P>
<DIV><FONT face=3DArial =
size=3D2>java.lang.NullPointerException</FONT></DIV>
<P><FONT face=3DArial size=3D2>at=20
temProvider.java:109)</FONT></P>
FactoryItemDelegator.java:93)</FONT></P>
t(ItemPropertyDescriptor.java:171)</FONT></P>
criptor.java:140)...</FONT></P></BODY></HTML>
------=_NextPart_000_000A_01C39FAE.2B888900--
Re: NPE in XSDAnnotationItemProvider [message #32628 is a reply to message #32560] Mon, 03 November 2003 07:46 Go to previous message
--------------71694B39F14BD2205687AFBC
Content-Type: text/plain; charset=us-ascii
Lance,
I'd be more tempted to prevent null from being added to the list in the
first place...
Lance Phillips wrote:
> Ed, Due to a problem with the way were reading in models, we were
> should be a bit more fault tolerant as this exception takes down the
> property sheet page and clutters up the log. Here is the stack... Oct
> java.lang.NullPointerExceptionjava.lang.NullPointerException at
> org.eclipse.xsd.provider.XSDAnnotationItemProvider.getText(X SDAnnotationItemProvider.java:109)
> at
> org.eclipse.emf.edit.provider.AdapterFactoryItemDelegator.ge tText(AdapterFactoryItemDelegator.java:93)
> at
> org.eclipse.emf.edit.provider.ItemPropertyDescriptor$ItemDel egator.getText(ItemPropertyDescriptor.java:171)
> at
> org.eclipse.emf.edit.ui.provider.PropertyDescriptor$1.getTex t(PropertyDescriptor.java:140)...
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Lance,
<p>I'd be more tempted to prevent null from being added to the list in
the first place...
<br>&nbsp;
<p>Lance Phillips wrote:
<blockquote TYPE=CITE><style></style>
<font face="Arial"><font size=-1>Ed,</font></font><font face="Arial"><font size=-1>&nbsp;&nbsp;&nbsp;
Due to a problem with the way were reading in models, we were creating
XSDAnnotations with null elements.&nbsp; We haven't quite solved that yet,
but an interesting side effect is a NPE in the XSDAnnotationItemProvider.&nbsp;
It would seem that the item provider should be a bit more fault tolerant
as this exception takes down the property sheet page and clutters up the
log.&nbsp; Here is the stack...</font></font>&nbsp;<font face="Arial"><font size=-1>Oct
31, 2003 12:48:08.062 [main|0] ERROR &lt;com.metamatrix.modeler.ui|0> java.lang.NullPointerException</font></font><font face="Arial"><font size=-1>java.lang.NullPointerException</font></font><font face="Arial"><font size=-1>at
org.eclipse.xsd.provider.XSDAnnotationItemProvider.getText(X SDAnnotationItemProvider.java:109) </font></font>
<p><font face="Arial"><font size=-1>at org.eclipse.emf.edit.provider.AdapterFactoryItemDelegator.ge tText(AdapterFactoryItemDelegator.java:93) </font></font>
<p><font face="Arial"><font size=-1>at org.eclipse.emf.edit.provider.ItemPropertyDescriptor$ItemDel egator.getText(ItemPropertyDescriptor.java:171) </font></font>
<p><font face="Arial"><font size=-1>at org.eclipse.emf.edit.ui.provider.PropertyDescriptor$1.getTex t(PropertyDescriptor.java:140)... </font></font></blockquote>
</html>
--------------71694B39F14BD2205687AFBC--
Re: NPE in XSDAnnotationItemProvider [message #580387 is a reply to message #32560] Mon, 03 November 2003 07:46 Go to previous message
Lance,
first place...
> at
> at
> at
<html>
Lance,
the first place...
<br>&nbsp;
</html>
Previous Topic:progress... but still stuck
Next Topic:XSD ItemProviders should use EMF pattern for creating PropertyDescriptors
Current Time: Fri May 09 08:08:40 EDT 2025
Powered by FUDForum. Page generated in 0.03625 seconds
