Home » Eclipse Projects » Equinox » ClassLoading/Security issue
ClassLoading/Security issue [message #32540] Sun, 11 January 2004 15:18 Go to next message
I have converted some of my plugins to OSGi bundles and it works fine:-)
But when coverting one using Jxta I got some trouble:
Jxta is defining a java.security.Provider and it
Re: ClassLoading/Security issue [message #32575 is a reply to message #32540] Sun, 11 January 2004 15:47 Go to previous messageGo to next message
I think my problem is related to this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=30919
Cheers
Sten
"Sten Ernerot" <ernerot@attglobal.net> wrote in message
news:btsau4$78b$1@eclipse.org...
> Hi
Re: ClassLoading/Security issue [message #32644 is a reply to message #32575] Sun, 11 January 2004 20:59 Go to previous messageGo to next message
Originally posted by: jeff_mcaffer.ca.ibm.com
Sten,
That's what I was thinking. I noted something curious in your code
ClassLoader sysloader = ClassLoader.getSystemClassLoader();
Class loaded = sysloader.loadClass( Cryptix.class.getName());
You should look carefully at the error that results. I suspect you are
actually getting the classload error on the Cryptix.class.getName() not on
the loadClass(). While it is possible that the compiler optimizes this out
(theoretically it knows the name of the class since it found it at compile
time) I don't think they worry about that as an optimization.
So what you are doing is trying to load Cryptix with the classloader that
loaded your method just to get the name and then trying to load it again
using the SystemClassLoader. As noted in bug 30919, only the Boot
classloader is available to plugins. In this case you should just be able
to put in the actual full name for Cryptix and be happy.
One thing confuses me. You say that this works in older versions of Eclipse
and not M6. Can you confirm that the exact same code runs in say M5 but
does not run in M6? (OSGi was introduced after M5).
Jeff
news:btsclr$8v1$1@eclipse.org...
> Cheers
> Sten
> > Hi
Re: ClassLoading/Security issue [message #32714 is a reply to message #32644] Mon, 12 January 2004 04:23 Go to previous messageGo to next message
Thanks for your replay.
Actually I cannot confirm it worket in earlier version.
I think it worked due to the fact that I earlier added the classes
with -Djava.endorsed.dirs
I will try your suggestions, and get back.
Sten
"Jeff McAffer" <jeff_mcaffer@ca.ibm.com> wrote in message
news:btsv0b$ol4$1@eclipse.org...
> Sten,
out
Eclipse
> Jeff
> > Cheers
> > Sten
> > > Hi
fine:-)
Re: ClassLoading/Security issue [message #32768 is a reply to message #32644] Mon, 12 January 2004 10:56 Go to previous messageGo to next message
After some further checking...
I does not matter if I change
to
Class loaded = sysloader.loadClass( "cryptix.provider.Cryptix");
since the SystemClassLoader does not have any knowlegde of my classpath
entries only the launcher startup classes.
Jxta tries to load the classes on system level, if not it loads it using the
class classloader.
The class gets loaded but then it doesnt work. I guess this is a question
for the Jxta list to avoid when classpath doesnt get set during the "normal"
vm startup.
Any input appreciated
Sten
> Sten,
out
Eclipse
> Jeff
> > Cheers
> > Sten
> > > Hi
fine:-)
Re: ClassLoading/Security issue [message #33242 is a reply to message #32768] Wed, 14 January 2004 11:32 Go to previous messageGo to next message
Originally posted by: jeff_mcaffer_REMOVE.ca.ibm.com
Sorry, I was assuming that the Cryptix stuff was in the endorsed or
extensions dirs and so the challenge here was loading from the system vs the
boot classloader.
If you try to load the class from your plugin's classloader then it should
prereq the plugin containing the Cryptix code. Does that make sense?
Jeff
news:btufui$gs7$1@eclipse.org...
> to
the
> class classloader.
"normal"
> vm startup.
> Regards
> Sten
> > Sten,
on
> out
compile
that
able
> Eclipse
> > Jeff
> > > Cheers
> > > Sten
> > > > Hi
> fine:-)
Re: ClassLoading/Security issue [message #33956 is a reply to message #33242] Fri, 16 January 2004 11:33 Go to previous message
Actually I found that the actual problem was something else. (Log4J was not
on the classpath and that causes another unloadable and then and then...
Thanks for your input.
Sten
"Jeff McAffer" <jeff_mcaffer_REMOVE@ca.ibm.com> wrote in message
news:bu3qtt$upg$1@eclipse.org...
the
> boot classloader.
> Jeff
> > to
> the
> > class classloader.
question
> "normal"
> > vm startup.
> > Regards
> > Sten
> > > Sten,
are
not
> on
this
> > out
> compile
> that
again
> able
> > Eclipse
but
> > > Jeff
> > > > Cheers
> > > > Sten
> > > > > Hi
> > fine:-)
Previous Topic:Importing existing Bundles
Next Topic:Wich OSGi services are planned
Current Time: Sun May 11 19:18:25 EDT 2025
Powered by FUDForum. Page generated in 0.03575 seconds
