Home » Eclipse Projects » Plugin Development Environment (PDE) » Create a branding plugin, installable via Update Site
Create a branding plugin, installable via Update Site [message #32506] Thu, 13 November 2008 09:11
I am rather new to eclipse plug-in development and I am faced with the
challenge to come up with a branding plugin that customizes the splash
screen, alters the bunch of standard icons and all the typical branding
items. These look like standard things but in my case it is preferrable
that it happens through an update site. Is there a way to incorporate this
branding functionality into an update site, which you call from an
out-of-the-box eclipse installation? As far as I understood changes in
config.ini file are required if you want to set a new splash screen and a
certain default perspective on startup, and I am not sure how this file
can get changed when the whole branding plug-in is triggered via an update
site.
Any help will be appreciated! Thanks!
petko
Previous Topic:Test framework doesn't create XML reports, how to?
Next Topic:Create a branding plugin, installable via Update Site
Current Time: Fri May 09 15:18:25 EDT 2025
Powered by FUDForum. Page generated in 0.04009 seconds
