Home » Archived » XML Schema Definition (XSD) » progress... but still stuck
progress... but still stuck [message #32490] Thu, 30 October 2003 17:17 Go to next message
Ed,
We're making some progress. When I read in my legacy model, I'm able to
get references to XSD Simple datatypes via the GlobalResourceSet as you
suggested. I end up with hrefs that look like this :
<baseTypeDefinition
href=" platform:/plugin/org.eclipse.xsd_1.1.1/cache/www.w3.org/2001 /XMLSchema
..xsd#//NMTOKENS;XSDSimpleTypeDefinition=32"/>
However, when I try to reload the xmi resource that contains this kind of
ref, the xmi resource is unable to resolve the reference. Any ideas on what
we're still missing? We've tried explicity loading the xsd file referenced
above into our resource set prior to trying to open the converted xmi model
and that didn't seem to help either.
thanks,
lp
Re: progress... but still stuck [message #32525 is a reply to message #32490] Fri, 31 October 2003 08:53 Go to previous messageGo to next message
Ed,
We were able to get past the problem listed below by using an href of the
form :
The EObject proxies that are created are resolvable through the
EcoreUtil.resolve(...).
thanks,
-dennis
"Lance Phillips" <lphillips@metamatrix.com> wrote in message
news:bns2kh$ejr$1@eclipse.org...
> Ed,
to
> <baseTypeDefinition
what
referenced
model
> thanks,
> lp
Re: progress... but still stuck [message #32594 is a reply to message #32490] Mon, 03 November 2003 07:10 Go to previous message
--------------D8454CDEB562C138931FD7F6
Content-Type: text/plain; charset=us-ascii
Lance,
I see that I should really take advantage of some of the latest features in EMF
that weren't available when I began the XSD work. It would be awfully nice if
the "global" references were of the form
http://www.w3.org/2001/XMLSchema#//..
rather than
platform:/plugin/org.eclipse.xsd_1.1.1/cache/www.w3.org/2001 /XMLSchema.xsd#//..
This could be accomplished with a URI map...
The XSD model's global resource set is populated on demand by calls like
XSDSchemaImpl.getSchemaForSchema. So if nothing has prompted the schema for
schema instance to be created, the XSD global resource set will be empty.
Probably that's the thing missing in your scenario.
Lance Phillips wrote:
> Ed,
> <baseTypeDefinition
> thanks,
> lp
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Lance,
<p>I see that I should really take advantage of some of the latest features
in EMF that weren't available when I began the XSD work.&nbsp; It would
be awfully nice if the "global" references were of the form
<blockquote><A HREF="http://www.w3.org/2001/XMLSchema#//">http://www.w3.org/2001/XMLSchema#//</A>..</blockquote>
rather than
<blockquote> platform:/plugin/org.eclipse.xsd_1.1.1/cache/www.w3.org/2001 /XMLSchema.xsd#//.. </blockquote>
<p>The XSD model's global resource set is populated on demand by calls
like XSDSchemaImpl.getSchemaForSchema. So if nothing has prompted the schema
for schema instance to be created, the XSD global resource set will be
empty.&nbsp; Probably that's the thing missing in your scenario.
<br>&nbsp;
<p>Lance Phillips wrote:
<blockquote TYPE=CITE>Ed,
<br>&nbsp;&nbsp;&nbsp; We're making some progress.&nbsp; When I read in
<br>get references to XSD Simple datatypes via the GlobalResourceSet as
you
<br>suggested.&nbsp; I end up with hrefs that look like this :
<br>&lt;baseTypeDefinition
<br>href=" platform:/plugin/org.eclipse.xsd_1.1.1/cache/www.w3.org/2001 /XMLSchema
<br>.xsd#//NMTOKENS;XSDSimpleTypeDefinition=32"/>
<p>However, when I try to reload the xmi resource that contains this kind
of
<br>ref, the xmi resource is unable to resolve the reference.&nbsp; Any
ideas on what
<br>we're still missing?&nbsp; We've tried explicity loading the xsd file
referenced
<br>above into our resource set prior to trying to open the converted xmi
model
<br>and that didn't seem to help either.
<p>thanks,
<p>lp</blockquote>
</html>
--------------D8454CDEB562C138931FD7F6--
Re: progress... but still stuck [message #580318 is a reply to message #32490] Fri, 31 October 2003 08:53 Go to previous message
Ed,
form :
thanks,
-dennis
> Ed,
to
> <baseTypeDefinition
what
referenced
model
> thanks,
> lp
Re: progress... but still stuck [message #580367 is a reply to message #32490] Mon, 03 November 2003 07:10 Go to previous message
Lance,
rather than
> Ed,
> <baseTypeDefinition
> thanks,
> lp
<html>
Lance,
rather than
<br>&nbsp;
you
of
ideas on what
referenced
model
<p>thanks,
<p>lp</blockquote>
</html>
Previous Topic:NPE in XSDAnnotationItemProvider
Next Topic:NPE in XSDAnnotationItemProvider
Current Time: Mon Sep 01 01:56:21 EDT 2025
Powered by FUDForum. Page generated in 0.04620 seconds
