Home » Archived » Service Component Architecture (SCA) Tools » Extending the sca diagram editor
Extending the sca diagram editor [message #2779] Mon, 08 September 2008 01:50 Go to next message
Hi.
I am trying to extend the diagram editor. Where should i start ? I m
interested in automating the editor so that:
1) i can add more items in the palette
2) drag & drop items from the palette to the components
3) right click the binding and open the associated editor in another page.
Thanks.
Re: Extending the sca diagram editor [message #2796 is a reply to message #2779] Mon, 08 September 2008 04:17 Go to previous messageGo to next message
Dameer Joog a écrit :
> Hi.
> Thanks.
items 1) and 2) are implemented. Have a look at [0].
Currently, we can add new binding, implementation and interface types.
I'm waiting a sign from the Eclipse fundation to commit the code [1].
item 3)
Have a look at
org.eclipse.stp.sca.diagram.customactions.OpenEditorAction.j ava
Take this class as a draft. We haven't yet defined extension points. If
you have any idea, don't hesitate to submit a bug [2].
Stéphane Drapeau
Obeo
[0]: https://bugs.eclipse.org/bugs/show_bug.cgi?id=236221
[1]: https://dev.eclipse.org/ipzilla/show_bug.cgi?id=2575
[2]:
https://bugs.eclipse.org/bugs/buglist.cgi?query_format=advan ced&short_desc_type=allwordssubstr&short_desc=&c lassification=STP&product=SOA&component=org.eclipse. stp.sca
Re: Extending the sca diagram editor [message #2813 is a reply to message #2779] Tue, 09 September 2008 07:56 Go to previous messageGo to next message
Originally posted by: joachim.roth.gmx.at
Dameer Joog schrieb:
> Hi.
> Thanks.
Hi.
I'm also browsing through the stp.SCA / stp.Policy fragments these Days.
My Intention would be to use / implement a diagramm representation of
the SCA-policy part. Am I rigth thers is nothing like that yet or did I
just not find it so far?
SCA Policy [message #2831 is a reply to message #2813] Tue, 09 September 2008 09:05 Go to previous messageGo to next message
>> Hi.
>> page.
>> Thanks.
> Hi.
Hi Joachim,
You're right, there is nothing like that. We said yesterday, on the
stp-dev mailing list [0], that we want/must work on this issue ;)
If you've ideas or if you want to develop something, don't hesitate.
I created a wiki page where you can put some ideas [1]. You're wellcome.
Stéphane Drapeau
Obeo
[0]: http://dev.eclipse.org/mhonarc/lists/stp-dev/msg01954.html
[1]: http://wiki.eclipse.org/STP/SCA_Component/SCA_Policy
Re: Extending the sca diagram editor [message #502187 is a reply to message #2779] Mon, 07 December 2009 01:15 Go to previous messageGo to next message
Hi Guys,
Will you please guide me how you added new diagram, with drag and drop functionality, in SCA pallete.
I also want to do the same thing.
Thanks for your cooperation.
Re: Extending the sca diagram editor [message #502234 is a reply to message #502187] Mon, 07 December 2009 05:41 Go to previous messageGo to next message
Hi Anubhav,
To extend the SCA Designer, you have to follow two steps:
(1) First, create a new plugin where you define a new ecore that extends
the SCA Meta Model. Then, generate the code. The namespace mustn't be
the open SOA one. More information can be found here [0].
(2) Then, create a new plugin (...diagram). Edit the plugin.xml file and
add the extension points needed to add your new SCA elements in the SCA
Designer. More information here [1].
Have a look also to the code specific to Tuscany and FraSCAti. You can
find it in the svn [2].
Stephane Drapeau
Obeo
[0]: http://wiki.eclipse.org/STP/SCA_Component/SCA_MMExtension
[1]:
http://wiki.eclipse.org/STP/SCA_Component/SCA_CompositeDesig nerExtension
[2]:
http://dev.eclipse.org/svnroot/stp/org.eclipse.stp.sca-tools /org.eclipse.stp.sca/trunk/
Anubhav a écrit :
> Hi Guys,
Re: Extending the sca diagram editor [message #572977 is a reply to message #2779] Mon, 08 September 2008 04:17 Go to previous messageGo to next message
> Hi.
> Thanks.
item 3)
Have a look at
Stéphane Drapeau
Obeo
[2]:
Re: Extending the sca diagram editor [message #573015 is a reply to message #2779] Tue, 09 September 2008 07:56 Go to previous messageGo to next message
> Hi.
> Thanks.
Hi.
SCA Policy [message #573048 is a reply to message #2813] Tue, 09 September 2008 09:05 Go to previous messageGo to next message
>> Hi.
>> page.
>> Thanks.
> Hi.
Hi Joachim,
Stéphane Drapeau
Obeo
Re: Extending the sca diagram editor [message #576660 is a reply to message #2779] Mon, 07 December 2009 01:15 Go to previous messageGo to next message
Hi Guys,
Re: Extending the sca diagram editor [message #576706 is a reply to message #576660] Mon, 07 December 2009 05:41 Go to previous messageGo to next message
Hi Anubhav,
Stephane Drapeau
Obeo
[1]:
[2]:
Anubhav a écrit :
> Hi Guys,
Re: Extending the sca diagram editor [message #842440 is a reply to message #2779] Thu, 12 April 2012 05:48 Go to previous messageGo to next message
Now I working in a extension to sca tools. I'm trying to add an element inside the sca component.
I am very new in the SCA subject and also in eclipse plugin extension.
I have already read this contribution to that subject. But it is a kind of old and the most part of the link don't exist right now. I hope than you can give some hint to start my own work. Any kind of information o clue will be totally appreciated.
Regards.
Re: Extending the sca diagram editor [message #857414 is a reply to message #2779] Thu, 26 April 2012 10:10 Go to previous messageGo to next message
Can you describe a little bit what you want to add in the model?
Is it a new interface? A new binding? A new implementation?
Re: Extending the sca diagram editor [message #1699636 is a reply to message #857414] Thu, 25 June 2015 08:35 Go to previous message
hi, i am now doing some developing about SCA,and i met some difficulties with it,could you please guide me how you added new diagram,
(1)i can add more items in the palette,such as a model called event like component to the composite
(2) it can be drag & drop from the palette to the composite
Previous Topic:Exceptions appears in my first SCA composite application
Next Topic:Problems regenerating the diagram code
Current Time: Fri Jul 25 14:03:43 EDT 2025
Powered by FUDForum. Page generated in 0.06292 seconds
