Home » Eclipse Projects » Eclipse Platform » [How to] launch browser on url
[How to] launch browser on url [message #2778] Tue, 22 April 2003 11:30 Go to next message
Hey all,
I need to launch a browser from my plugin on a url of the form:
http://sourceforge.net/forum/forum.php?thread_id=853477& forum_id=265703
I found something in the archive about org.eclipse.swt.program.Program,
but that looks to only launch an associated program for a (html) file.
Is there a way to programmatically do this?
thanks,
Todd
Re: [How to] launch browser on url [message #2795 is a reply to message #2778] Tue, 22 April 2003 11:33 Go to previous messageGo to next message
Originally posted by: genadyb.inter.net.il
I want to do that myself, but apparently it requires to check the
platform and run the appropriate command. I found this technique in
the code of the about dialog box ( I don't remember what class it was )
Todd Chambery wrote:
> Hey all,
> thanks,
> Todd
Re: [How to] launch browser on url [message #2934 is a reply to message #2795] Tue, 22 April 2003 13:21 Go to previous messageGo to next message
Thanks for the hint. The 3 methods in ProductInfoDialog did what I needed:
openLink(String href)
openWebBrowser(String href)
openWebBrowserError(Display display)
Copied them into my plugin and got it open the browser on my link.
Todd
>> Hey all,
>> org.eclipse.swt.program.Program, but that looks to only launch an
>> thanks,
>> Todd
>> Hey all,
>> thanks,
>> Todd
Re: [How to] launch browser on url [message #2986 is a reply to message #2934] Tue, 22 April 2003 13:35 Go to previous messageGo to next message
Is there some way to use the browser specified in
Window/Preferences/Help/Current Web Browser Adapter?
Those APIs seem to call up mozilla on my system, whereas, I'd prefer it to
use the "sensible-browser" program that all my other programs use (and
Help/Help Contents uses).
> Todd
Re: [How to] launch browser on url [message #3003 is a reply to message #2986] Tue, 22 April 2003 13:39 Go to previous messageGo to next message
Check out the browser extension point in org.eclipse.help
Re: [How to] launch browser on url [message #3020 is a reply to message #3003] Tue, 22 April 2003 13:42 Go to previous messageGo to next message
sorry, that's for defining web browsers. But you might be able to get at:
org.eclipse.help.internal.HelpSystem.getHelpBrowser()
(it's public/static for now)
Re: [How to] launch browser on url [message #3037 is a reply to message #3020] Tue, 22 April 2003 14:02 Go to previous messageGo to next message
This works (and I'm using it), but I'm a little sketchy about using the
internal stuff since the APIs can change...
Re: [How to] launch browser on url [message #3062 is a reply to message #3037] Tue, 22 April 2003 14:18 Go to previous messageGo to next message
Yeah, though the update plugin also uses these internal APIs (in
particular:
org.eclipse.update.internal.ui.views.DetailsView.showURL()
There's also this class, which nobody seems to use yet:
org.eclipse.help.ui.browser.LaunchURL
Re: [How to] launch browser on url [message #4440 is a reply to message #3020] Tue, 22 April 2003 15:19 Go to previous message
If you need to use browser support from help plug-in, use
org.eclipse.help.internal.browser.BrowserManager.createBrows er() to get your
IBrowser instance rather than using same instance as help. Also, the
BrowserManager class is less likely to get changed, than HelpSystem class.
Konrad Kolosowski
"Michael R Head" <burner@zclipse.org> wrote in message
news:pan.2003.04.22.17.42.38.353192@zclipse.org...
Previous Topic:PDE Help
Next Topic:What's happening after 2.1?
Current Time: Sun Jul 27 06:28:52 EDT 2025
Powered by FUDForum. Page generated in 0.05382 seconds
