How to redirect -consolelog output to a file? [message #319917] |
Wed, 05 September 2007 17:42 |
Originally posted by: nicolas.grossi.gmail.com
People:
I have a .bat file as follow:
eclipse.exe -perspective mypackage.customperspective -consolelog
If i run this .bat file on windows two windows are loaded. One runs
de.bat command and another have the -consolelog output.
Is there any way to redirects -consolelog output to file?
I have tried:
eclipse.exe -perspective mypackage.customperspective -consolelog >
myfile.txt
but no success.
Nico
Re: How to redirect -consolelog output to a file? [message #319975 is a reply to message #319971] |
Thu, 06 September 2007 18:57 |
--------------010304070908010902050509
Alex & Andrew:
Actually I'm using a "custom" RCP eclipse distribution
and I have included the eclipsec.exe to my dist but i'm getting the
attached error because there is some .jar file missing. Does any of you
knows wich is the requiered .jar to use eclipsec.exe instead of eclipse.exe?
thanks in advance once again,
Nico
Andrew Niefer wrote:
> Alex Blewitt wrote:
>> Use eclipsec.exe instead of eclipse.exe
>> Alex
> As Alex said, use eclipsec.exe. On Windows, it is the OS that handles
> initially allocating a console and connecting the i/o pipes. It chooses
> to do this based on how the exe was linked (gui or console). The
> eclipsec executable was linked as a console application so Windows
> behaves much better about redirecting the pipes.
> -Andrew
Content-Type: image/png;
name="1.png"
Content-Disposition: inline;
filename="1.png"
iVBORw0KGgoAAAANSUhEUgAAAS4AAAByCAIAAABiGassAAAACXBIWXMAAA7E AAAOxAGVKw4b
AAAAB3RJTUUH1wkGEjQ1Ga/7UAAAAAd0RVh0QXV0aG9yAKmuzEgAAAAMdEVY dERlc2NyaXB0
aW9uABMJISMAAAAKdEVYdENvcHlyaWdodACsD8w6AAAADnRFWHRDcmVhdGlv biB0aW1lADX3
DwkAAAAJdEVYdFNvZnR3YXJlAF1w/zoAAAALdEVYdERpc2NsYWltZXIAt8C0 jwAAAAh0RVh0
V2FybmluZwDAG+aHAAAAB3RFWHRTb3VyY2UA9f+D6wAAAAh0RVh0Q29tbWVu dAD2zJa/AAAA
BnRFWHRUaXRsZQCo7tInAAABAElEQVR4nO3dXa/URBzH8X/NiVcaUCMGCCho jOgRD4aHlQhx
34M3vgGvNOAjIAg5IKIYiURfgddcnEsuN6ICPgIBQkwkgsFnI4nerxdlh55O O512O+1/u9+P
BLu77cx0tj+m7Xa7IgAAIBZdPHem7TYAkGg4HLbdBgAyIyKXzp9tuxnAtJuJ /7f5+U+jKBKR
KIokkkhuPxpNinnBvGI9EOtxZlGjAtNz3yow479F5ZWoJaO4Wy9mF5W5UgUt HBVYvgfyihq1
sFRRmSub8w4WruztlfLqzOxNIrN/0m139UCJthV1pruonJW1WphZaXKuytbf eeWO6ksDqM9M
2w0AOuWFTUv8rdnL1AAAAQBJREFUZ+73+y8eXYiniSJQM8+TLycWTiYflt5B /fvCsb8uHCu7
FAC3RaPifz98kny4ZN0Ox5J/nv9QRJZteD1Es4AOmJ3riUjyo3v7GSNjB/Xu x142558c1dz/
1GujM0gAMlw8d2Z2rjc714uz58ih+Bwr3rz0kZm+98lXzLQZFf/4/oPk/Ms3 7oonbnx1xDy5
qrdXRK5/+Y555qFn344nrn42b5585Lnb00AHmDSah3lzZkTx3ysfxxNL1u24 efm4iNzzxE4p
+uTkgaffjCL57dujv37z/opNu3/5+j0RWblljxlgr58+LCIPbt0nUXTti0M/ fX5ozbb9V08d
FJGHtx9IfhD/mCMAAAEASURBVPwEdEmcRnHmUMbZQfVx4+wREVnVe8s8cy0x MALTwAyJZk81
U6gPM8zAKCI/n3k33kGV0ahorrYJVDugRHI8TB432gJebbNy856VW/aEKx9Q LrVfmjx5Yys4
Vlz6+I6bl4//Mzpzkzxtk/L7d0fjieUbd0VRZIZEubWDGq1+Zu/104eTO6hr tu1fu23/1VMH
fxydueG0DbrEHgB9d1DvevSl1GXHIrL0iZ3Ji4nvW/9qfH4l9WFGfNrGPF6x affiokREVm/d
l7ocXETWbj+w+JpcYBpx4RtQs9QVbZ5qiOKyDW/UcroV6IB+v19tQUZFoE7m mxZl8X1FQIVo
OBxyQw3ZMAF1AAABAElEQVSgdYyKgApEEVCBKAIqEEVABaIIqEAUARWIIqAC UQRUIIqACkQR
UIEoAioQRUAFogioUE8U8+6co6G0dtnrUrh2Na7+xPVkhe6qXLI2VaIY30PO /Am0uP6+i01K
O7sqdP97lh/PNk5jqnyL39xDzn2348ISxp8HUGL8zbW2G2rYvwrg8zsB7sXN Hc7dJftXbS+Y
qq6wNMciYzamsE/sqmvpHFNU6gePUpV69o9dQqnWVusud/9nzuzukMwZ3OV7 bgwOtUXR7nd7
k022O7mUe4B1lCw5b3lmafacZmZ7gyssLbOFdmszn3FMO1bcXXVea33el1I7 OBX6x7FGtXSX
f6/6THjpEQAAAQBJREFUvL8VmlTYGB8BbzPl2G8eczS301i5SZnZHrNtdc0Z 6CgosxPy5vTp
n3EOVWrsrrq4KyrVjFI9EzCKgQ727N2ACv8qjzlPntS/muNUVKqoUupdQfvt GKc0h0CbU0ph
k8pubP4908TniiH+PcvbBfVc3MxpH8ZUKG1MjVXkX29yMPTZC20mJ7G2uivF sxntj4rJ7Tvv
ONu86jlz5qGwvWxeafbz9tZWWJqd24uJX8/LTLVnY1IcFTmUKrZCfuw25JVW trXuAh3Nzut/
z9Wv/P66y6/Qz9pvvjjOcQgwQbjwDVBB+6gITAlGRUCFqYhivefc8s5b1F4R psoERHEitu+J
aB6JbzAAAAEASURBVCQ0m4AoTsQZ1IloJDSr+Lmi+7O+5EP7mozknI5lk8+4 a5GsJLhbmDlD
8rNsx/x5HZLXSEexyVd9rm9Eh1WJon1RYt4VtMlNMHWRWqln3LW4mxTzWdae ECtLUpRJR7GF
r2Katf+rw+EuenZv4na9qTDX1RJ3scmU2rHH9Gg5ioEuek7uDWZu1jVe9esv 3BXe6IAJOG1T
WS1xajIz9pBIYqdHxRtq5F1BW7j1Oy7GLVVpqVrcpfnU5d9OR9X+hWAKNXrh G0dBbvTPNOvy
DiowQbgcHFCBURFQgSgCKhBFQAWiCKhAFAEViCKgAlEEVCCKgApEEVCBKAIq EEVABaIIqEDr
kOJrAAABAElEQVQUARWIIqACUQRUIIqACu3ffLGrOn8bG+79US+iGNBwOGy7 CUH0+/3BYNB2
K7qGKIbVvZuVnFg42XYTuoljRUAFotiQ+NBx0v9GONzxLZTZuZ7p227c4DRe ixMLJweDwWAw
6MAaqcKo2IRubLXdWAu1iGITQuzdzc714j+ZtQSqsfYyYXAGtQm1jyfu30UN tD/MqBgUo2IT
6h1PUklL/SpOuONSRsWgiGITGhtPgp4fYlQMiig2oRvjSTfWQi2i2ITGxpOg P+HIqBgUUWxC
vfFwHxyGSyOjYlCcQW1C7eOJ+zeY7R8Sr6vSegtEEqNiE0KMJ/FPr6fGw8zp ujAqBkUUsKa0
pwAAAH9JREFUm9CN8aQba6EWUWxCN8aTbqyFWkSxCebQbqL/ZlQMim9mhJL8 ZkaX8M2MQDiD
GhbfeYcnohhQv99vuwmYGEQxIO7FBH8cKwIqcAYVUIEoAioQRUAFogioQBQB FYgioAJRBFQg
ioAKRBFQgSgCKhBFQIWZ+fn5ttsAQP4H9bMXpzltktwAAAAASUVORK5CYII=
--------------010304070908010902050509--
Re: How to redirect -consolelog output to a file? [message #319981 is a reply to message #319975] |
Thu, 06 September 2007 22:28 |
Originally posted by: automatic.javalobby.org
It's the same one that eclipse.exe uses. However, if you've copied an eclipsec.exe from 3.3 and are expecting it to work with a 3.2 app, you would get that error message. The solution would be to upgrade your RCP to work on the 3.3 RCP base rather than the 3.2 RCP base.
Alex.
FUDForum. Page generated in 0.02825 seconds
