Home » Eclipse Projects » Eclipse Platform » How to batch multiple changes to a document so that it can be undone with a single undo ?
How to batch multiple changes to a document so that it can be undone with a single undo ? [message #319876] Wed, 05 September 2007 02:02 Go to next message
------=_NextPart_000_006D_01C7EF93.1CBFA0A0
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_006E_01C7EF93.1CBFA0A0"
------=_NextPart_001_006E_01C7EF93.1CBFA0A0
Content-Type: text/plain;
charset="Windows-1252"
BlankHi,
In my plug-in I have to edit the same IDocument (in an editor), on =
several places.
My problem is that I can't find a way to do my changes to the document, =
so that the user could undo them with a single undo command.
Is there any way to do this?
If there is, where can I find an examples?
Right now I create a ReplaceEdit for each change, add them to a =
MultiTextEdit object and finally call the apply method of this object to =
do the actual change to the document.
The apply method does take a "style" parameter, but no matter how I set =
it, the result is the same.
Thanks in advance
Kristof
Content-Type: text/html;
<HTML><HEAD><TITLE id=3DridTitle>Blank</TITLE>
charset=3Dwindows-1252"><BASE=20
href=3D"file://C:\Program Files\Common Files\Microsoft =
Shared\Stationery\">
<STYLE>BODY {
MARGIN-TOP: 25px; FONT-SIZE: 10pt; MARGIN-LEFT: 25px; COLOR: #000000; =
FONT-FAMILY: Arial, Helvetica
P.msoNormal {
MARGIN-TOP: 0px; FONT-SIZE: 10pt; MARGIN-LEFT: 0px; COLOR: #ffffcc; =
FONT-FAMILY: Helvetica, "Times New Roman"
LI.msoNormal {
</STYLE>
<META content=3D"MSHTML 6.00.2800.1597" name=3DGENERATOR></HEAD>
<BODY id=3DridBody bgColor=3D#ffffff=20
background=3Dcid:006801c7ef82$59354a00$e3c66b9f@eemea.ericsson.se>
<DIV>Hi,</DIV>
<DIV>&nbsp;</DIV>
<DIV>In my plug-in I have to edit the same IDocument (in an editor), on =
several=20
places.</DIV>
<DIV>My problem is that I can't find a way to do my changes to the =
document, so=20
that the user could undo them with a single undo command.</DIV>
<DIV>&nbsp;</DIV>
<DIV>Is there any way to do this?</DIV>
<DIV>If there is, where can I find&nbsp;an examples?</DIV>
<DIV>&nbsp;</DIV>
<DIV>Right now I create a ReplaceEdit for each change, add them to a=20
do the=20
actual change to the document.</DIV>
<DIV>The apply method does take a "style" parameter, but no matter how I =
set it,=20
the result is the same.</DIV>
<DIV>&nbsp;</DIV>
<DIV>Thanks in advance</DIV>
<DIV>&nbsp;</DIV>
<DIV>Kristof</DIV>
<DIV>&nbsp;</DIV></BODY></HTML>
------=_NextPart_001_006E_01C7EF93.1CBFA0A0--
Content-Type: image/gif;
name="Blank Bkgrd.gif"
Content-ID: <006801c7ef82$59354a00$e3c66b9f@eemea.ericsson.se>
R0lGODlhLQAtAID/AP////f39ywAAAAALQAtAEACcAxup8vtvxKQsFon6d02 898pGkgiYoCm6sq2
7iqWcmzOsmeXeA7uPJd5CYdD2g9oPF58ygqz+XhCG9JpJGmlYrPXGlfr/Yo/ VW45e7amp2tou/lW
xo/zX513z+Vt+1n/tiX2pxP4NUhy2FM4xtjIUQAAOw==
------=_NextPart_000_006D_01C7EF93.1CBFA0A0--
Re: How to batch multiple changes to a document so that it can be undone with a single undo ? [message #319885 is a reply to message #319876] Wed, 05 September 2007 07:11 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
What happens when you do this? Does each change get given its own undo?
Alex.
Re: How to batch multiple changes to a document so that it can be undone with a single undo ? [message #319886 is a reply to message #319885] Wed, 05 September 2007 07:25 Go to previous messageGo to next message
Exactly.
Each change receives its own undo.
Kristof
"Alex Blewitt" <automatic@javalobby.org> wrote in message
news:805524705.6351188990750262.JavaMail.root@cp9.dzone.com...
> Alex.
Re: How to batch multiple changes to a document so that it can be undone with a single undo ? [message #319909 is a reply to message #319876] Wed, 05 September 2007 12:14 Go to previous messageGo to next message
Kristof Szabados wrote:
> several places.
> document, so that the user could undo them with a single undo command.
> to do the actual change to the document.
> set it, the result is the same.
This should work. If it doesn't please file a bug report against
Platform Text with steps / test case to reproduce. You could also try
the RewriteSessionEditProcessor.
Dani
> Thanks in advance
> Kristof
Re: How to batch multiple changes to a document so that it can be undone with a single undo ? [message #319939 is a reply to message #319909] Thu, 06 September 2007 05:24 Go to previous message
Thanky this fully solved my problem.
Kristof
"Daniel Megert" <daniel_megert@ch.ibm.com> wrote in message
news:fbmkmt$hqo$1@build.eclipse.org...
> > Hi,
> > several places.
> Dani
> > Thanks in advance
> > Kristof
Previous Topic:problems when using embedded jars
Next Topic:Using Sub Projects
Current Time: Fri Jul 18 11:29:20 EDT 2025
Powered by FUDForum. Page generated in 0.07971 seconds
