Home » Language IDEs » PHP Development Tools (PDT) » Outline views remaining blank
Outline views remaining blank [message #2765] Thu, 01 March 2007 09:12 Go to next message
Originally posted by: bernhard.schussek.at
Hello!
I installed PDT 0.7.0.v20070221 in my Eclipse 3.2 platform on Linux
Ubuntu 6.10 Edgy Eft yesterday. I installed it using the update manager
and the official download source on download.eclipse.com.
After removing PHPEclipse, the install went fine and I can successfully
launch Eclipse with the new plugin, open the different perspectives,
configure it etc.
The primary problem that I have is that the outline views remain empty
for any PHP files/projects. The normal outline is empty, the PHP
Projects Outline contains the three headers "Constants", "Classes" and
"Functions" without any content. The PHP Functions view works fine
though. Additionally, I can't fold anything in the code. Syntax
highlighting works, but the [+] and [-] for folding code blocks are not
available.
What can I do? Is it a problem with this release? Did I misconfigure
anything?
Thanks in advance for your support.
Bernhard
Re: Outline views remaining blank [message #2800 is a reply to message #2765] Fri, 02 March 2007 02:36 Go to previous messageGo to next message
Bernhard Schussek wrote:
> Hello!
> configure it etc.
> available.
> anything?
Did you write new code in PDT, or did you load your existing PHPEclipse
plug-ins into PDT? (if yes - how did you do that?)
For now, there's no automatic mechanism for migrating from PHPEclipse
to PDT, the workarround is: create new projects in PDT, and copy your files
into new projects.
Hope this helps.
Michael
Re: Outline views remaining blank [message #2817 is a reply to message #2765] Fri, 02 March 2007 04:48 Go to previous messageGo to next message
> Hello!
> configure it etc.
> available.
> anything?
I had the same issues. I described the migration in
http://cakebaker.42dh.com/2006/12/27/migration-from-phpeclip se-to-php-ide/
based on a tip I got here in this group.
HTH
Daniel Hofstetter
Re: Outline views remaining blank [message #2852 is a reply to message #2817] Fri, 02 March 2007 10:32 Go to previous message
> HTH
Thanks for the tip! I simply deleted all projects in Eclipse and their
..project files and then created them newly. Now it works.
Previous Topic:Re: This newsgroup is moving.
Next Topic:What ha
Current Time: Tue Jul 22 12:01:17 EDT 2025
Powered by FUDForum. Page generated in 0.04581 seconds
