Problem using © character [message #32224] |
Wed, 12 November 2008 11:37  |
Originally posted by: jmordax.terra.es
Hi, I have used this character © in a Feature Descriptor at Provider field.
Problem is that when I go to Help -> About, and I check the details of
my Feature, that character appears like ©.
I have tested such character in a SWT table successfully, so I suspect
the problem is how the Feature Descriptor is managed later.
Have you seen this behavior before? Is it related to PDE? Should I
comment in other group (I don't know who is in charge of get and show
that info in About window)?
Thanks in advance,
Chemi.
Re: Problem using © character [message #37138 is a reply to message #32365] |
Thu, 11 December 2008 16:03  |
As workaround I have found that you can export that string to
plugin.properties file and then it is shown correctly. Problem happens
when such character is used directly in MANIFEST.MF or plugin.xml files.
Chemi.
Re: Problem using © character [message #584886 is a reply to message #32224] |
Thu, 13 November 2008 07:21  |
Originally posted by: benjamin.cabe.anyware-tech.com
https://bugs.eclipse.org/bugs/show_bug.cgi?id=255036 has been filed.
Cheers
Benjamin
> Thanks in advance,
> Chemi.
Re: Problem using © character [message #586961 is a reply to message #32365] |
Chemi.
FUDForum. Page generated in 0.45800 seconds
