Home » Eclipse Projects » Eclipse Platform » [Databinding] Observing checked Items in a TableViewer with SWT.CHECK
[Databinding] Observing checked Items in a TableViewer with SWT.CHECK [message #318793] Mon, 06 August 2007 15:08 Go to next message
Originally posted by: tom.eiswind.de
HI, I'm quite new to JFace Databinding. One of the first things I run into was that I have a TableViewer from which you
can select a subset of values by checking the checkboxes of the table. I tried to refactor it so that it gets integrated
with databinding. I wanted to subclass JavaBeanObservableList for the ease of it, but that is not accessible. What I
want is to have a List of all checked items in the viewer that I can bind with databinding. What I think of is something
like:
public class TableViewerCheckBoxSelectionList extends JavaBeanObservableList
implements IChangeListener {
private IObservableList input;
private TableViewer tableViewer;
public TableViewerCheckBoxSelectionList(TableViewer viewer, Realm realm,
Object object, PropertyDescriptor descriptor, Class elementType) {
super(realm, object, descriptor, elementType);
if (!(viewer.getInput() instanceof IObservableList)) {
throw new IllegalArgumentException(
"Input must be an IObservableList");
input = (IObservableList) viewer.getInput();
tableViewer = viewer;
setCheckedItems();
viewer.getTable().addListener(SWT.Selection, new Listener() {
public void handleEvent(Event e) {
if (e.detail == SWT.CHECK) {
handleCheckEvent(e);
addChangeListener(this);
public void handleChange(ChangeEvent event) {
setCheckedItems();
private void setCheckedItems() {
TableItem[] items = tableViewer.getTable().getItems();
for (int i = 0; i < items.length; i++) {
items[i].setChecked(contains(items[i].getData()));
private void handleCheckEvent(Event e) {
TableItem item = (TableItem) e.item;
Object checked = item.getData();
if (item.getChecked() == true) {
add(checked);
} else {
remove(checked);
Any Idea how I could implement this ? Hope this is a good start to the newsgroup.
Re: [Databinding] Observing checked Items in a TableViewer with SWT.CHECK [message #318995 is a reply to message #318793] Thu, 09 August 2007 12:10 Go to previous messageGo to next message
I helped myself with the following solution. Maybe you can integrate sth like this in the framework ?
It binds an ObservableSet to the checked items of a TableViewer. It so simple then.
public class TableViewerCheckBoxBinding implements ISetChangeListener {
private IObservableSet checked;
public TableViewerCheckBoxBinding(TableViewer viewer, IObservableSet checked) {
this.tableViewer = viewer;
this.checked = checked;
setCheckedItems();
checked.addSetChangeListener(this);
public void handleSetChange(SetChangeEvent event) {
setCheckedItems();
items[i].setChecked(checked.contains(items[i].getData()));
Object check = item.getData();
checked.add(check);
} else {
checked.remove(check);
> into was that I have a TableViewer from which you can select a subset of
> so that it gets integrated with databinding. I wanted to subclass
> What I want is to have a List of all checked items in the viewer that I
> can bind with databinding. What I think of is something like:
> realm,
> elementType) {
> setCheckedItems();
> @Override
> setCheckedItems();
> add(checked);
> } else {
> remove(checked);
> newsgroup.
Re: [Databinding] Observing checked Items in a TableViewer with SWT.CHECK [message #319032 is a reply to message #318995] Fri, 10 August 2007 01:45 Go to previous message
Did you file an enhancement request in bugzilla for this? If not please
do so.
Tom
> simple then.
> checked) {
> setCheckedItems();
> @Override
> setCheckedItems();
> checked.add(check);
> } else {
>> it so that it gets integrated with databinding. I wanted to subclass
>> I can bind with databinding. What I think of is something like:
>> realm,
>> elementType) {
>> setCheckedItems();
>> @Override
>> setCheckedItems();
>> add(checked);
>> } else {
>> remove(checked);
>> newsgroup.
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Previous Topic:Adding Tasks to the TaskList using TODO
Next Topic:Eclipse crashes
Current Time: Fri Jul 18 05:38:57 EDT 2025
Powered by FUDForum. Page generated in 0.09593 seconds
