Home » Eclipse Projects » GEF » Connection Anchors
Connection Anchors [message #32168] Wed, 16 October 2002 00:46 Go to next message
If I uses ChopBox connection Anchors for a figure, can I just create 1
instance of ChopBox connection anchor for all incoming connections and
outgoing connections? Or I need 1 chopbox connection anchor per connection?
Thank you.
Re: Connection Anchors [message #32203 is a reply to message #32168] Wed, 16 October 2002 03:17 Go to previous message
"yinglcs" <yinglcs@netscape.com> wrote in message
news:aoipea$rf2$1@rogue.oti.com...
connection?
You can use only once instance of you ChopboxAnchor for all incoming /
outgoing connections.
You have a supposed "minimal" code sample demo called "Hello Gef 2" that
does what you want on http://eclipsewiki.swiki.net/ in GEF / Example, or
http://eclipsewiki.swiki.net/50#hellogef2 for direct link.
Alex.
Previous Topic:Best place to move anchors depending on node's figure size after a resize?
Next Topic:draw2d and gef
Current Time: Sat May 03 03:53:01 EDT 2025
Powered by FUDForum. Page generated in 0.04075 seconds
