Running OSGi [message #32148] |
Fri, 09 January 2004 12:10  |
Could someone point me to the document on running the OSGi container and
installing Bundles and Plugins?
Stephen
Re: Running OSGi [message #32780 is a reply to message #32435] |
Tue, 13 January 2004 10:49   |
Thanks for the reply. That's what I was looking for.
I have an application that is a combination of some general purpose
bundles and a large client bundle (written in SWT and JFace). The package
dependencies for the client bundle are pretty unwieldy. Up to now I've
used Oscar embedded in an application with the classpath already setup to
avoid them (with obvious drawbacks concerning dynamic bundles). I've also
spent some time to get it deployed into SMF, but that was too painful for
general development purposes. I was hoping to convert the client bundle
into a set of smaller bundle fragments and use equinox instead. However,
I couldn't figure out how to install my general purpose bundles into the
OSGi container. This did the trick.
While we're at it, since the client is limited to JFace and SWT, what's
the minimum set of plugins I can use to run a standalone OSGi container.
Stephen
Jeff McAffer wrote:
> Stephen,
> We are working on the doc now. Can you be more specific as to what
> information you need or what you are trying to do?
> We don't draw any real distinction between plugins and bundles. There are
> two ways of specifying the runtime dependencies, plugin.xml and manifest.mf.
> Currently not all parts of Eclipse support plugins/bundles which only have a
> manifest.mf so you will see plugin.xmls hanging around in places whree there
> is a manifest.mf. I fyou give just a plugin.xml, we generate a manifest.mf
> for you.
> If you are happy with that, then you can use the regular Eclipse install
> story (see the doc for more info). In either case, you cna use the OSGi
> console (run eclipse -console) and use the "install" command.
> Jeff
> "Stephen" <stephen.goldbaum@lehman.com> wrote in message
> news:btmnab$2hg$1@eclipse.org...
> > Thanks,
> > Stephen
Re: Running OSGi [message #32885 is a reply to message #32780] |
Tue, 13 January 2004 14:48   |
To be even more specific: The application has a single main window that
launches various other windows via a toolbar and popup menus. So I'd like
to run the container with only a single perspective and a toolbar.
Besides the update manager, every other feature of a standard PDE
workspace should be removed. I was also looking for documentation on how
I might manage this since it seems that I can't start the workspace when I
remove much of the unnecessary functionality. At the very least, I'd like
to be able to run a standalone OSGi container with a minimal set of the
OSGi services (that would be helpful regardless of the application).
-Stephen
> Stephen
> Jeff McAffer wrote:
> > Stephen,
manifest.mf.
a
there
> > for you.
> > Jeff
> > > Thanks,
> > > Stephen
Re: Running OSGi [message #32920 is a reply to message #32885] |
Tue, 13 January 2004 15:00   |
I think you can strip most things out.
I have played around with RPC and running a stripped version of the
workbench.
Some code will still be there but you choose wich actions you want to put in
there.
Cheers
Sten
"Stephen Goldbaum" <stephen.goldbaum@lehman.com> wrote in message
news:bu1i2v$7ea$1@eclipse.org...
> -Stephen
package
to
also
for
However,
> > Stephen
> > Jeff McAffer wrote:
> > > Stephen,
are
> manifest.mf.
have
> a
> there
manifest.mf
> > > for you.
install
OSGi
> > > Jeff
and
> > > > Thanks,
> > > > Stephen
Re: Running OSGi [message #32991 is a reply to message #32920] |
Tue, 13 January 2004 15:03   |
Should be RCP (Rich Client Platform):-)
-Sten
"Sten Ernerot" <ernerot@attglobal.net> wrote in message
news:bu1ik8$81m$1@eclipse.org...
> workbench.
in
> there.
> Cheers
> Sten
like
how
I
like
> > -Stephen
> package
I've
> to
> also
> for
bundle
> However,
the
what's
container.
> > > Stephen
> > > Jeff McAffer wrote:
> > > > Stephen,
There
> are
> > manifest.mf.
only
> have
> > a
whree
> > there
> manifest.mf
> > > > for you.
> install
> OSGi
> > > > Jeff
container
> and
> > > > > Thanks,
> > > > > Stephen
Re: Running OSGi [message #33177 is a reply to message #33025] |
Wed, 14 January 2004 11:26  |
Originally posted by: jeff_mcaffer_REMOVE.ca.ibm.com
You might look at Ed Burnette's stuff on eclipsepowered.org.
As for the minimal set, really all you need is
org.eclipse.osgi.*
org.eclipse.core.runtime
That gets you a headless eclipse that should be launchable from the PDE
runtime workbench launch config. There may be some complaint about
update.configurator being missing but that is only an issue running outside
of PDE and if you don't want to setup the configuration ahead of time.
Keep asking these questions. We are doing doc and it helps.
Jeff
news:bu1jq0$9j4$1@eclipse.org...
> Thanks. That sounds good. Could you point me to some RCP documentation?
> -Stephen
> > -Sten
> > > workbench.
put
> > in
> > > there.
> > > Cheers
> > > Sten
FUDForum. Page generated in 0.04073 seconds
