Home » Eclipse Projects » Eclipse Platform » ANT Problem: failed to create task or type scp
ANT Problem: failed to create task or type scp [message #318330] Wed, 25 July 2007 16:56 Go to next message
I installed a fresh copy of 3.3, the did Run As > Ant build
on a (test case file) having the following content:
<?xml version="1.0" encoding="UTF-8" ?>
<project name="jschtest" default="tryscp" basedir=".">
<target name="tryscp">
<scp file="../index.html"
todir="root@somehost:/opt/scpdest/ password=pwdeh">
</scp>
</target>
</project>
The build failed with the following error:
E:\swd\workspaces\mould-site-wksp\site1.scentable.com\html\b uilds\build.xml:4:
Cause: Could not load a dependent class com/jcraft/jsch/UserInfo
It is not enough to have Ant's optional JARs
you need the JAR files that the optional tasks depend upon.
Ant's optional task dependencies are listed in the manual.
Action: Determine what extra JAR files are needed, and place them in one of:
-C:\sop-eclipse\installs\3.3\eclipse\plugins\org.apache.ant_ 1.7.0.v200706080842\lib
-C:\Documents and Settings\Bill Winspear\.ant\lib
-a directory added on the command line with the -lib argument
Do not panic, this is a common problem.
The commonest cause is a missing JAR.
This is not a bug; it is a configuration problem
I copied jsch-0.1.20.jar into ...org.apache.ant_1.7.0.v200706080842\lib,
as suggested above, booted eclipse and tried again.... with the same result.
Ok, I'm not in a panic, but I am stumped.
How can I get the ANT scp comand to run on 3.3?
Bill.
Re: ANT Problem: failed to create task or type scp [message #318341 is a reply to message #318330] Thu, 26 July 2007 00:34 Go to previous messageGo to next message
Add jsch JAR to the Ant runtime classpath.
Window>Preferences>Ant>Runtime>Classpath
Select Global Entries and pick Add External JARs
HTH
Darins
"Bill Winspur" <bwinspur@wynnon.com> wrote in message
news:f88d7m$396$1@build.eclipse.org...
> <scp file="../index.html" todir="root@somehost:/opt/scpdest/
> password=pwdeh">
> </scp>
> </target>
> </project>
> of:
> result.
> Bill.
Re: ANT Problem: failed to create task or type scp [message #318360 is a reply to message #318341] Thu, 26 July 2007 11:22 Go to previous message
Thanks Darin that worked, Bill.
> HTH
> Darins
>>password=pwdeh">
>></scp>
>></target>
>></project>
>>of:
>>result.
>>Bill.
Previous Topic:Move to Eclipse 3.3 - do I have to reinstall all of my plugins?
Next Topic:java.lang.NoClassDefFoundError: org/eclipse/pde/internal/ui/editor/plugin/ManifestEditor
Current Time: Sat Nov 08 22:50:23 EST 2025
Powered by FUDForum. Page generated in 0.03763 seconds
