Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Using JNI with Eclipse+MTJ
Using JNI with Eclipse+MTJ [message #32116] Mon, 13 July 2009 06:23 Go to next message
I'm having trouble trying to use JNI with Eclipse and MTJ. My VM
implementation supports JNI so I am trying to create a Midlet that uses
it. I have included the external libraries that implement JNI in the
project build path (but not exported them). Also, in the "Native Library
Location" I give the folder that contains the native libraries (.dll and
h). I am able to compile my project successfully, however I get a
preverification error in the class that declares the native method.
Please, does anyone has some ideas that could help me solve this problem?
Thanks a lot in advance.
María
Re: Using JNI with Eclipse+MTJ [message #32151 is a reply to message #32116] Mon, 13 July 2009 07:08 Go to previous messageGo to next message
Originally posted by: craigjunk.setera.org
Maria,
What SDK are you using that supports JNI?
Craig
Maria Amor wrote:
> Hello,
> Best regards,
> María
Re: Using JNI with Eclipse+MTJ [message #32184 is a reply to message #32151] Mon, 13 July 2009 07:31 Go to previous messageGo to next message
Hello Craig,
Thanks for your quick answer.
Well, I'm using Sun's Wireless Toolkit 2.5.2. I donŽt have any specific
SDK that supports JNI, but my VM does support it (I use IBM's J9).
María
Re: Using JNI with Eclipse+MTJ [message #32459 is a reply to message #32184] Wed, 15 July 2009 07:22 Go to previous messageGo to next message
Given that MIDP doesn't, by default, allow for JNI you aren't going to
be able to use Sun's toolkit for this work. The preverification will fail.
Maria Amor wrote:
> Hello Craig,
> María
Re: Using JNI with Eclipse+MTJ [message #32494 is a reply to message #32459] Wed, 15 July 2009 07:30 Go to previous messageGo to next message
To answer your question via email...
I have no idea what SDK you could use for this testing. It would have
to look like a standard ME SDK for MTJ to be able to use it.
> Maria Amor wrote:
>> Hello Craig,
>> Regards,
>> María
Re: Using JNI with Eclipse+MTJ [message #33101 is a reply to message #32494] Mon, 20 July 2009 03:13 Go to previous message
OK. Thank you Craig. So far, I havenŽt found that SDK. I'll let you know
if I do.
Re: Using JNI with Eclipse+MTJ [message #574693 is a reply to message #32116] Mon, 13 July 2009 07:08 Go to previous message
Maria,
Craig
Maria Amor wrote:
> Hello,
> Best regards,
> María
Re: Using JNI with Eclipse+MTJ [message #574716 is a reply to message #32151] Mon, 13 July 2009 07:31 Go to previous message
Hello Craig,
María
Re: Using JNI with Eclipse+MTJ [message #574886 is a reply to message #32184] Wed, 15 July 2009 07:22 Go to previous message
Maria Amor wrote:
> Hello Craig,
> María
Re: Using JNI with Eclipse+MTJ [message #574935 is a reply to message #32459] Wed, 15 July 2009 07:30 Go to previous message
> Maria Amor wrote:
>> Hello Craig,
>> Regards,
>> María
Re: Using JNI with Eclipse+MTJ [message #575243 is a reply to message #32494] Mon, 20 July 2009 03:13 Go to previous message
if I do.
Previous Topic:ClassNotFoundException when two classes are defined in the same java file
Next Topic:ClassNotFoundException when two classes are defined in the same java file
Current Time: Tue Aug 12 15:32:16 EDT 2025
Powered by FUDForum. Page generated in 0.05050 seconds
