Home » Eclipse Projects » Simultaneous release » Re: Subversive ready for Ganymede?
Re: Subversive ready for Ganymede? [message #2750] Tue, 04 March 2008 17:39 Go to next message
Originally posted by: erkki.lap.ee
Is this a permanent issue or are the legal issues going to get solved at
some point? If not, then this seems like a pretty bad joke -- Subclipse
at least can be installed from a single update site, which makes a third
party plug-in more easily installable than Eclipse.org's "official" SVN
provider.
Currently the feature on the Ganymede site will be installed without any
connector and the user left to figure out what he is supposed to do get
one and not everyone is going to realise what is missing or where to
find a link to the additional update site ( like
http://www.eclipse.org/subversive )
Erkki
Alexander Gurov wrote:
> Dear Hiroki,
> Due to Eclipse legal restrictions native connector also is not included
> into the Subversive plug-in distribution and should be installed from
> the Polarion.org site. So, regarding to this we returned SVN Kit 1.1.4
> as default connector. Also we added two SVN 1.5-compatible connectors:
> Native JavaHL 1.5.0 development build and SVN Kit 1.2.0 development build.
Re: Subversive ready for Ganymede? [message #2767 is a reply to message #2750] Wed, 05 March 2008 06:16 Go to previous messageGo to next message
Hi Erkki,
We work together with Eclipse Foundation to find a solution for legal
issues, because it's not only usability problem. In particular, this legal
issue seems as blocker for project inclusion in standard distribution
packages, etc. Every party here, like Subversive team, Technology PMC,
Eclipse Foundation, really want to close legal issues, but it's really
complicated process. Anyway, we already made step forward in this direction
and as the result Subversive became an Eclipse project. I beleive that
someday we will find a solution, which allows us to distribute a project as
one package.
Igor Vinnykov
"Erkki Lindpere" <erkki@lap.ee> ???????/???????? ? ???????? ?????????:
news:fqkj3f$le8$1@build.eclipse.org...
> some point? If not, then this seems like a pretty bad joke -- Subclipse at
> provider.
> one and not everyone is going to realise what is missing or where to find
> Erkki
>> Dear Hiroki,
>> into the Subversive plug-in distribution and should be installed from the
>> Polarion.org site. So, regarding to this we returned SVN Kit 1.1.4 as
>> build.
Subversive ready for Galileo? [message #2974 is a reply to message #2767] Sat, 04 April 2009 13:23 Go to previous messageGo to next message
As German Language Champion I'm currently testing Babel Language packs while
working with Eclipse.
And the 2 biggests "Problem Children" regarding an otherwise often up to 99%
translation are:
- Mylyn
- Subversive
I even installed what you call "Team Provider Localization (Optional)" but
whatever that means to localize, the SVN Repository perspective for Example
is still all English.
I know, other (legal) issues may keep you busy, but for a vendor already
from Germany I would call this a little embarrassing, at least for its
native language ;-)
Let me know, if you need any help on that? Babel Support is also a killer
criterium to being ready for Galileo! Not just some ongoing legal "babel"
Werner
Re: Subversive ready for Galileo? [message #2991 is a reply to message #2974] Mon, 06 April 2009 07:32 Go to previous messageGo to next message
Hello Werner,
Now we don't have any Babel translations for Subversive, I fired a bug about
this problem. "Team Provider Localization (Optional)" contains only french
and japan translations, but they are quite obsolete and I've also
contributed them to Babel.
Sorry, I don't fully understand the problem you wrote about, could you
please describe it in more details?
> while working with Eclipse.
> 99% translation are:
> - Mylyn
> - Subversive
> Example is still all English.
> native language ;-)
> Cheers,
> Werner
Re: Subversive ready for Galileo? [message #3008 is a reply to message #2991] Fri, 10 April 2009 10:40 Go to previous messageGo to next message
Your problem is, that unless Babel is supported, Subversive will never be
considered for Galileo Release train !!!
Unless of course, there are still other issues like the odd 2 way
installation which prevents Subversive from this??;-)
Re: Subversive ready for Galileo? [message #3025 is a reply to message #2991] Sat, 11 April 2009 10:51 Go to previous messageGo to next message
See this "Must Do" for Galileo:
- Localization The project participates in Babel, meaning it is registered
and available for string translation, etc. M6 Script
( http://wiki.eclipse.org/Galileo_Simultaneous_Release#Must_Do)
According to the Wiki page, Subversive plans to participate, but not being
registered with Babel means, it may not be accepted.
Werner
Re: Subversive ready for Galileo? [message #4020 is a reply to message #3025] Mon, 13 April 2009 05:00 Go to previous messageGo to next message
Hello Werner,
Subversive really was registered in Babel long ago (you can check it in
http://babel.eclipse.org/babel/map_files.php by selecting
technology.subversive project in projects list) but there are no
translations for it, I already reported about it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=268926.
I also marked bug relative to corresponding Simultaneous Release requirement
as WONTFIX.
Unfortunately I can't check why there are no translations, so if it's
possible could you please check it?
Thanks for taking attention to Subversive project.
> registered and available for string translation, etc. M6 Script
> Werner
Re: Subversive ready for Galileo? [message #4037 is a reply to message #4020] Mon, 13 April 2009 06:05 Go to previous messageGo to next message
Since Subversive normally won't be preinstalled anyway (just take the
license issue, which also still looks WONTFIX ?;-) that may be acceptable as
long as Babel is supported.
You should no longer have those separate "i18n" updates though!
Did you provide the sources for that to Babel?
I could forward your last post to the Babel newsgroup, but beside that I
cannot help you as long as it does not show up in the Babel Translation
server.
"Igor Burilo" <igor.burilo@polarion.org> schrieb im Newsbeitrag
news:gruuul$7gd$1@build.eclipse.org...
> Hello Werner,
> requirement as WONTFIX.
>> being registered with Babel means, it may not be accepted.
>> Werner
Re: Subversive ready for Galileo? [message #4107 is a reply to message #4020] Mon, 13 April 2009 12:22 Go to previous messageGo to next message
The CVS Team client works perfectly well in German thanks to Babel!
It is a shame, you guys are too lazy to simply use some of these
translations.
Beside the fact, that Polarion as a German company should at least be
capable of their own native language (well for most of you at least ;-)
Re: Subversive ready for Galileo? [message #4177 is a reply to message #4107] Mon, 13 April 2009 12:27 Go to previous messageGo to next message
> translations.
Werner, the syncup script will sync up those translations where they
match english strings from the CVS client to the SVN client.
Re: Subversive ready for Galileo? [message #4247 is a reply to message #4037] Tue, 14 April 2009 03:44 Go to previous messageGo to next message
Hello Werner,
I contributed our translations ("i18n") to Babel, for more details please
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=258783.
I will remove our "i18n" plugins as soon as we have Babel translations.
I marked bug corresponding to Galileo Simultaneous Release requirement
"Localization - Babel"
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=254172) as 'wontfix'
following to advices from "Reminder and instructions to completeG-bugs" post
from cross-project mailing list: "For one, if you don't think you'll be able
to do something ... or, you think maybe there is a 50/50 chance you'll be
able to pull it off at the last minute, then don't wait, just mark is "won't
fix" and give some explanation as to why."
If any additional steps are required from our side, please, note it.
> as long as Babel is supported.
> server.
>> Hello Werner,
>>> Werner
Re: Subversive ready for Galileo? [message #4317 is a reply to message #4177] Thu, 16 April 2009 14:38 Go to previous message
Sounds good.
Re: Subversive ready for Ganymede? [message #566965 is a reply to message #2750] Wed, 05 March 2008 06:16 Go to previous message
Hi Erkki,
one package.
Igor Vinnykov
> provider.
> Erkki
>> Dear Hiroki,
>> build.
Subversive ready for Galileo? [message #567292 is a reply to message #2767] Sat, 04 April 2009 13:23 Go to previous message
translation are:
- Mylyn
- Subversive
native language ;-)
Werner
Re: Subversive ready for Galileo? [message #567329 is a reply to message #2974] Mon, 06 April 2009 07:32 Go to previous message
Hello Werner,
> - Mylyn
> - Subversive
> native language ;-)
> Cheers,
> Werner
Re: Subversive ready for Galileo? [message #567356 is a reply to message #2991] Fri, 10 April 2009 10:40 Go to previous message
Re: Subversive ready for Galileo? [message #567379 is a reply to message #2991] Sat, 11 April 2009 10:51 Go to previous message
Werner
Re: Subversive ready for Galileo? [message #567406 is a reply to message #3025] Mon, 13 April 2009 05:00 Go to previous message
Hello Werner,
as WONTFIX.
> Werner
Re: Subversive ready for Galileo? [message #567424 is a reply to message #4020] Mon, 13 April 2009 06:05 Go to previous message
server.
> Hello Werner,
>> Werner
Re: Subversive ready for Galileo? [message #567439 is a reply to message #4020] Mon, 13 April 2009 12:22 Go to previous message
translations.
Re: Subversive ready for Galileo? [message #567464 is a reply to message #4107] Mon, 13 April 2009 12:27 Go to previous message
> translations.
Re: Subversive ready for Galileo? [message #567490 is a reply to message #4037] Tue, 14 April 2009 03:44 Go to previous message
Hello Werner,
> server.
>> Hello Werner,
>>> Werner
Re: Subversive ready for Galileo? [message #567515 is a reply to message #4177] Thu, 16 April 2009 14:38 Go to previous message
Sounds good.
Previous Topic:Galileo packages
Next Topic:3.5M7
Current Time: Thu May 08 15:19:18 EDT 2025
Powered by FUDForum. Page generated in 0.33169 seconds
