Home » Archived » OFMP » Questions/suggestions about the proposal
Questions/suggestions about the proposal [message #2745] Mon, 20 August 2007 11:17 Go to next message
Originally posted by: frederic.conrotte.kaupthing.lu
Welcome to the OFMP newsgroup.
Do not hesitate to post comments on our proposal :
http://www.eclipse.org/proposals/ofmp/
Frederic Conrotte
Co-Project Lead
Re: Questions/suggestions about the proposal [message #2763 is a reply to message #2745] Mon, 20 August 2007 23:49 Go to previous messageGo to next message
This project is a great idea and I'd definitely consider getting
involved. The only immediate question I have concerns your choice of
the term "Platform" instead of "Framework". Is there a particular
point you're trying to make with this designation?
I look forward to seeing the initial code contribution (are you taking
advantage of the Parallel IP process?). Also, if you have a set of
architectural/design docs from the original project, it would be great
to see those on a project wiki. They could be placed in a "historical"
bin to avoid confusing them with actual planning docs.
Congratulations and best of luck on this project!
--- Patrick Paulin
patrick@rcpquickstart.com
In article <facbak$ke4$1@build.eclipse.org> "Frederic
> Frederic Conrotte
> Co-Project Lead
Re: Questions/suggestions about the proposal [message #2780 is a reply to message #2763] Tue, 21 August 2007 02:45 Go to previous messageGo to next message
"Patrick Paulin" <patrick@rcpquickstart.com> wrote in message
news:nemoMon082007103638@news.eclipse.org...
> involved.
Great ! You're more than welcome.
We tought "OFF" was not a too good idea :-)
More seriously, the main point about the "Platform" is that we do want OFMP
to :
* "just work" after basic installation.
* be an integration point for existing tools (Mathematical libraries, Batch
jobs scheduling, etc)
we do not wish it to be just a "non integrated" collection of tools.
Indeed we'll submit our Forex Middle Office Platform to Parallel IP Process.
>Also, if you have a set of architectural/design docs from the original
For sure we'll do it if the project is created and our Eclipse OFMP wiki
setup.
Frederic
OFMP and EclipseLink [message #2816 is a reply to message #2745] Wed, 29 August 2007 11:09 Go to previous messageGo to next message
Hi Frederic,
I just wanted to introduce the incubating Eclipse Persistence Services
project (nicknamed 'EclipseLink').
EclipseLink will provide access to a variety of backend data sources
including relational and Enterprise Information Systems (EIS) via JCA. I
see from the proposal you have a need for data access from Java so there
may be some synergy between our two projects. I also expect you have some
Java to/from XML conversion needs which EclipseLink also has support for
with JAXB and SDO implementations. Please take a look at our homepage
(below) for some background on the project. We'd love to be able to help
with OFMP's data access and XML needs!
Shaun Smith
EclipseLink Ecosystem Development Lead
EclipseLink Homepage: http://www.eclipse.org/eclipselink
EclipseLink newsgroup:
http://www.eclipse.org/newsportal/thread.php?group=eclipse.t echnology.eclipselink
Re: OFMP and EclipseLink [message #2851 is a reply to message #2816] Fri, 31 August 2007 12:29 Go to previous messageGo to next message
Hi Shaun,
Indeed our OFMP planning includes migrating to EclipseLink framework.
For us it's very important to have frameworks like EclipseLink available,
because Interfacing and Integration with various legacy Financial EIS is a
crucial topic.
I will attend your talk during ESE to a more in depth view about the status
of the project.
Frederic
"Shaun Smith" <shaun.smith@oracle.com> wrote in message
news:89b432ca01f8727ba4ba21a5053e55a9$1@www.eclipse.org...
> Hi Frederic,
> Shaun Smith
Re: OFMP and EclipseLink [message #2868 is a reply to message #2851] Fri, 31 August 2007 16:00 Go to previous message
> of the project.
That's great Frederic! I look forward to meeting you and seeing how our
projects can work together!
--Shaun
Re: Questions/suggestions about the proposal [message #565859 is a reply to message #2745] Mon, 20 August 2007 23:49 Go to previous message
--- Patrick Paulin
> Frederic Conrotte
> Co-Project Lead
Re: Questions/suggestions about the proposal [message #565896 is a reply to message #2763] Tue, 21 August 2007 02:45 Go to previous message
> involved.
to :
setup.
Frederic
OFMP and EclipseLink [message #565940 is a reply to message #2745] Wed, 29 August 2007 11:09 Go to previous message
Hi Frederic,
Shaun Smith
Re: OFMP and EclipseLink [message #566023 is a reply to message #2816] Fri, 31 August 2007 12:29 Go to previous message
Hi Shaun,
crucial topic.
of the project.
Frederic
> Hi Frederic,
> Shaun Smith
Re: OFMP and EclipseLink [message #566049 is a reply to message #2851] Fri, 31 August 2007 16:00 Go to previous message
> of the project.
--Shaun
Previous Topic:Comments from RiskMetrics
Next Topic:Open Financial Market Platform
Current Time: Sat Jul 12 00:11:17 EDT 2025
Powered by FUDForum. Page generated in 0.05570 seconds
