Home » Eclipse Projects » Eclipse Platform » Ghosting effect using nested forms
Ghosting effect using nested forms [message #316852] Wed, 20 June 2007 04:21 Go to next message
Originally posted by: xuiterlinden.be-value.nl
We've just ported our application from SWT to RCP on eclipse 3.2.
In our application we're using nested FormToolkit forms. Where this
worked fine in eclipse 3.1, we're experiencing problems in eclipse
3.2.
When scrolling through my view, the widgets on the form are repainted
slowly ?? which causes a ghosting effect.
Below is an example View which demonstrates the effect.
I also tried the same code in 3.3RC4, but it gives the same ghosting
effect.
Anyone have an idea to fix this ?
-- Xander
------8<------------8<------------8<-------------8<-----------
public class View extends ViewPart {
public static final String ID = "ScrapbookPliugin.view";
* This is a callback that will allow us to create the viewer
and
initialize
* it.
public void createPartControl(Composite parent) {
Composite c = new Composite(parent, SWT.NONE);
c.setLayout(new FillLayout());
FormToolkit toolkit = new
FormToolkit(getViewSite().getShell().getDisplay());
ScrolledForm form = toolkit.createScrolledForm(c);
Composite body = form.getBody();
body.setBackground(Display.getCurrent().getSystemColor(SWT.C OLOR_YELLOW));
body.setLayout(new GridLayout());
for (int i = 0; i < 3; i++) {
createSection(toolkit, body, "Section " + i,
0);
public void createSection(FormToolkit toolkit, Composite
parent, String
label, int depth) {
Section section = null;
Composite sectionComposite = null;
GridLayout layout = null;
GridData data = null;
Text text = null;
Composite widgetsComposite = null;
Composite subsectionComposite = null;
section = toolkit.createSection(parent,
ExpandableComposite.TWISTIE |
ExpandableComposite.TITLE_BAR | ExpandableComposite.EXPANDED);
section.setText(label);
section.setBackground(Display.getCurrent().getSystemColor(SW T.COLOR_GREEN));
data = new GridData();
data.minimumWidth = 500;
data.widthHint = 500;
data.grabExcessHorizontalSpace = true;
data.horizontalAlignment = SWT.FILL;
if (depth > 0) {
data.horizontalIndent = 20;
section.setLayoutData(data);
sectionComposite = toolkit.createComposite(section);
layout = new GridLayout();
layout.numColumns = 1;
sectionComposite.setLayout(layout);
// create a widgets and a subsections composite
widgetsComposite =
toolkit.createComposite(sectionComposite);
subsectionComposite.setLayout(new GridLayout());
section.setBackground(Display.getCurrent().getSystemColor(SW T.COLOR_GRAY));
layout.numColumns = 2;
widgetsComposite.setLayout(layout);
section.setClient(sectionComposite);
for (int j = 0; j < 3; j++) {
toolkit.createLabel(widgetsComposite,
"Checkbox control");
toolkit.createButton(widgetsComposite,
"Check", SWT.CHECK);
for (int j = 0; j < 10; j++) {
toolkit.createLabel(widgetsComposite, "Label
for text");
text = toolkit.createText(widgetsComposite,
"Text control");
data.minimumWidth = 300;
data.widthHint = 300;
text.setLayoutData(data);
depth ++;
if (depth < 3) {
for (int i = 0; i < 2; i++) {
subsectionComposite, label + depth, depth);
* Passing the focus request to the viewer's control.
public void setFocus() {
Re: Ghosting effect using nested forms [message #316892 is a reply to message #316852] Thu, 21 June 2007 04:59 Go to previous messageGo to next message
Originally posted by: monikakrug.expires-2007-06-30.arcornews.de
Xander Uiterlinden schrieb:
> 3.2.
> effect.
Is this all the relevant code? Is there code outside what you showed
that is running a long-running operation on the UI thread (= the thread
where the Display was created)? That could cause other operations, like
repainting, to be delayed.
Monika.
All wars are civil wars, because all men are brothers ... Each one owes
infinitely more to the human race than to the particular country in
which he was born. - Francois Fenelon, theologian and writer (1651-1715)
E-mail address is valid until 4 weeks after the expiration date. Use
@arcor.de instead.
Re: Ghosting effect using nested forms [message #316897 is a reply to message #316892] Thu, 21 June 2007 06:59 Go to previous message
On Thu, 21 Jun 2007 10:59:14 +0200, Monika Krug
>> 3.2.
>> effect.
>Monika.
Yes, this actually is all the relevant code. It's not the actual code
in our product, but an reproduction which gives the same behaviour. If
you create a new plugin project en past this view into it, you'll see
the problem.
--Xander
Previous Topic:PackageExplorer in Perspective
Next Topic:.properties file for a library used in a plugin
Current Time: Sat Jul 26 09:18:32 EDT 2025
Powered by FUDForum. Page generated in 0.04622 seconds
