Home » Language IDEs » ServerTools (WTP) » Server (Tomcat, speciifically)
Server (Tomcat, speciifically) [message #31818] Mon, 26 July 2004 14:12 Go to next message
Originally posted by: richard.reich.com
Does anyone know how to wire up an existing project (that's not set up
as a "Dynamic Web Project") with the Tomcat support? I can't do it.
Seems you have to throw away your current project, completely redo your
cvs structure, create a "Dynamic Web Project", etc., to use the IBM
server support. Obviously, even if I liked the canned structure, I
can't do that.
Sysdeo.com's Tomcat plugin, lean and capable, seems to have figured out
exactly how to do this, if you need a hint.
-r
Re: Server (Tomcat, speciifically) [message #34138 is a reply to message #31818] Wed, 28 July 2004 21:27 Go to previous messageGo to next message
No suggestions? Is it not possible to use the IBM Tomcat server support
without starting a project from scratch and using only the canned
project structure? Or what?
-r
> can't do that.
> -r
Re: Server (Tomcat, speciifically) [message #34308 is a reply to message #34138] Thu, 29 July 2004 09:40 Go to previous messageGo to next message
Originally posted by: HeartBit.runeconsulting.com
why dont you try this. first, create a 'dummy' dynamic web project. and
then, copy ".*" files(such as .project and .classpath and etc.) to your
'existing' project. then 'f5' to refresh the 'existing project' and
bring a project properties(alt+enter) dialog of it, and fix whatever broken.
i hope this will work.
> -r
Re: Server (Tomcat, speciifically) [message #34885 is a reply to message #34308] Thu, 29 July 2004 21:42 Go to previous message
Yippee. I didn't do exactly what you suggest. I had previously looked
at the various .xxxxx config files, tried merging in a few things. But
that didn't work. But your note encouraged me to do it again. The
magic things are:
the WebNature item in .project
the .websettings directory with obvious changes
That did it. Thanks!
(Obviously a UI to do this simple stuff is required.)
-r
> broken.
>> support without starting a project from scratch and using only the
>> canned project structure? Or what?
>> -r
Previous Topic:Is this a problem with the dtd validator or a problem in the dtd?
Next Topic:webtools error
Current Time: Wed Jun 04 10:15:12 EDT 2025
Powered by FUDForum. Page generated in 0.05022 seconds
