Re: Java Code Highlight in Custom TextEditor [message #315517 is a reply to message #315512] |
Fri, 11 May 2007 08:45  |
Originally posted by: gritgop.pisem.net
My editor uses .java files. Those files are modified to add some text so
I'd need the coloring to ignore those added lines.
Would it be possible to reuse the coloring already used in the regular
..java editor?, if so, how could I do it?
Thanks.
Jacek Pospychala wrote:
> If your editor extends TextEditor it can have syntax highlighting like
> this in Java editor.
> But do you want your editor to edit java files?
> exquisitus wrote:
>> Hi.
>> Is is possible to create a custom editor that Extends TextEditor that
>> makes use of the Java source code highlight?
>> Thanks
FUDForum. Page generated in 0.44880 seconds
