Home » Modeling » OCL » Parsing problem.
Parsing problem. [message #31769] |
Tue, 03 July 2007 09:30  |
Hi all, I am working on some rules for a UML profile (constraints on
stereotypes), and can't seem to get this one right.
Let me explain the situation. The desired rule would be (in text):
"A component with this stereotype cannot use interfaces directly".
Ok, so, now in OCL. I will try to write it not so concise so that it can
be easily understood. Part A, B, and C are not in the code, I'm placing
them here so I can refer to each one independently. Context= the
stereotype applied to Component:
(Part A)
let d: Set(Dependency) = self.base_Component.clientDependency->select(e
| e.oclIsKindOf(Usage))
(Part B)
in let j: Set(Dependency) = d->select(supplier.oclIsKindOf(Interface))
(Part C)
in j->isEmpty()
That is one way of writing it, isn't it?, at least I thought it was.
However, I get a "Error... Iteration expression body must be a boolean
expresion..." (sorry I'm not thorough in the error message, but my IDE
doesn't let me copy it).
So, going through it piece by piece:
"Part A" is Ok, I think. At least it parses with no errors.
"Part C" is so simple, it can be wrong.
"Part B". Well, here is the problem. I get that
"supplier.oclIsKindOf(Interface)" is not a boolean expression!!.
Correct me if I'm wrong, but I am standing in a Set of Dependency, I get
each Dependency and ask if it's "supplier" role (an instance of
"NamedElement") is of the type or subtype of Interface, am I right?.
I don't see my mistake here. Perhaps I'm just too submerged on the
subject to see it.
I hope someone can enlighten me.
Thank you,
Juan Pedro
Re: Parsing problem. [message #31804 is a reply to message #31769] |
Tue, 03 July 2007 10:43   |
Sorry, I maid a mess. I should have said that LABELS "PartA", "Part B",
and "Part C" were not in the text.
The rest is fine.
> (Part A)
> (Part B)
> (Part C)
> in j->isEmpty()
> subject to see it.
> Thank you,
> Juan Pedro
Re: Parsing problem. [message #31912 is a reply to message #31769] |
Wed, 04 July 2007 11:28   |
Hi, Juan Pedro,
The problem with Part B is that the "supplier" property is multi-valued.
Thus,
is an abbreviation of
supplier->collect(e | e.oclIsKindOf(Interface))
which type is a collection of Booleans, not a Boolean.
Try this, instead:
supplier->exists(e | e.oclIsKindOf(Interface)))
HTH,
Christian
> (Part A)
> (Part B)
> (Part C)
> in j->isEmpty()
> subject to see it.
> Thank you,
> Juan Pedro
Re: Parsing problem. [message #32017 is a reply to message #31912] |
Thu, 05 July 2007 11:06   |
Christian, as usual, you couldn't be more right.
And yes, I was just too submerged on the
subject to see it.. :-)
Thank you very much.
Juan Pedro
Christian W. Damus escribió:
> Hi, Juan Pedro,
> Thus,
> Try this, instead:
> HTH,
> Christian
>> (Part A)
>> (Part B)
>> (Part C)
>> in j->isEmpty()
>> subject to see it.
>> Thank you,
>> Juan Pedro
Re: Parsing problem. [message #32052 is a reply to message #32017] |
Thu, 05 July 2007 12:02  |
heh heh ... only because I happen to be very familiar with the UML metamodel
and have actually seen this problem before. :-)
You're most welcome.
cW
> Juan Pedro
<snip>
Current Time: Sat Aug 02 04:33:41 EDT 2025
Powered by FUDForum. Page generated in 0.04785 seconds
