Home » Eclipse Projects » Eclipse Platform » Switching between 2 version of 1 plugin?
Switching between 2 version of 1 plugin? [message #314595] Wed, 18 April 2007 06:45 Go to next message
Hi all,
Is there any posibility to unload currently loaded plugin and load the same
plugin with different version (both available in plugins folder).
10x in advance,
Stoil
Re: Switching between 2 version of 1 plugin? [message #314601 is a reply to message #314595] Wed, 18 April 2007 07:57 Go to previous messageGo to next message
Originally posted by: valere.fedronic.ext.streamezzo.com
Help >> SoftwareUpdates >> manage configuration
Select the plugin and click on the *Replace with another version* link
in the right panel.
valere.
Stoil Valchkov wrote:
> Hi all,
> 10x in advance,
> Stoil
Re: Switching between 2 version of 1 plugin? [message #314615 is a reply to message #314601] Wed, 18 April 2007 10:13 Go to previous messageGo to next message
Is there way to do this from within plugin depending on another plugin with
multiple versions?
valere fedronic wrote:
> in the right panel.
> valere.
>> Hi all,
>> same plugin with different version (both available in plugins folder).
>> 10x in advance,
>> Stoil
Re: Switching between 2 version of 1 plugin? [message #314626 is a reply to message #314615] Wed, 18 April 2007 12:46 Go to previous messageGo to next message
I do not fully understand the question, but you can explicitly say in
your manifest.mf that you depend on a specific version of a plugin (the
properties.. button in the dependency tab).
And another plugin can depend on an other version of the same plugin,
there can be two version of the same plugin active at the same time.
valere.
> multiple versions?
>> in the right panel.
>> valere.
>>> Hi all,
>>> 10x in advance,
>>> Stoil
Re: Switching between 2 version of 1 plugin? [message #314682 is a reply to message #314595] Thu, 19 April 2007 08:49 Go to previous messageGo to next message
I think Valere mentioned that if you manage at the feature level, you
can disable and then enable different versions of a feature and that
will unload and load different plugins. Take a look at
org.eclipse.update.standalone.EnableCommand and DisableCommand to
understand the programmatic interface that would work.
At a lower level, you can use the OSGi PackageAdmin service and the
BundleContext to dynamically load and unload plugins.
Later,
PW
Re: Switching between 2 version of 1 plugin? [message #315072 is a reply to message #314626] Wed, 02 May 2007 06:53 Go to previous message
I meant replace loaded plugin during runtime. I suppose post of Paul Webster
is what I need.
Previous Topic:WorkspaceModifyOperation and WizardNewFileCreationPage
Next Topic:Eclipse 3.2.2 installation bug?
Current Time: Tue Sep 16 17:01:02 EDT 2025
Powered by FUDForum. Page generated in 0.03205 seconds
