Home » Eclipse Projects » Eclipse Platform » Junit - Testing a View
Junit - Testing a View [message #314575] Wed, 18 April 2007 00:09 Go to next message
Originally posted by: swetha.yahoo.co.in
I have a tree view, I have some actions which are added to the
ToolbarManager as follows,
IToolBarManager mgr = getViewSite().getActionBars().getToolBarManager();
mgr.add(exitAction);
When I am testing this method using JUnit, getViewSite() is coming as a
null and getting NullPointerException,
How can I get the getViewSite() not null;
Pls help me...
Swetha
Re: Junit - Testing a View [message #314680 is a reply to message #314575] Thu, 19 April 2007 08:40 Go to previous messageGo to next message
1) make sure you are running a JUnit plug-in test instead of a normal
JUnit test
2) make sure you open a workbench window and either find the view or
show it if it is not already visible.
Later,
PW
Re: Junit - Testing a View [message #314706 is a reply to message #314680] Fri, 20 April 2007 05:05 Go to previous messageGo to next message
Thanks for the reply.....I did the same but still getSite(),
getViewSite() are null only....
I am running it as a workbench only.. the workbench is closed after
executing all the test cases..
Swetha
Re: Junit - Testing a View [message #314717 is a reply to message #314706] Fri, 20 April 2007 09:23 Go to previous messageGo to next message
Please post the snippet that is your JUnit test method. The important
code ... how are you find the workbench window? How are you finding
your open view?
PW
Re: Junit - Testing a View [message #314752 is a reply to message #314717] Mon, 23 April 2007 00:33 Go to previous messageGo to next message
This is the test method..
public class CustomerViewTest extends TestCase
CustomerView custView;
@Before
public void setUp() throws Exception
custView = new CustomerView();
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().
showView("com.sequenom.everest.ui.CustomerView");
@After
public void tearDown() throws Exception
// Testing
@Test
public void testCreateTreeWidget()
custView.createWidget(PlatformUI.getWorkbench()
.getActiveWorkbenchWindow().getShell());
Assert.assertNotNull(custView.tree);
MouseEvent g;
custView.tree.getTree();
When I am testing the createWidget() method in CustomerView class , the
NullPointerExcepton is coming at the line,
getSite().setSelectionProvider(tree);
getSite() is coming as null;
Swetha
Re: Junit - Testing a View [message #314787 is a reply to message #314752] Tue, 24 April 2007 01:31 Go to previous messageGo to next message
Hi Paul,
Can u please help me why I am unable to access getViewSite() and
getSite()...
Swetha
Re: Junit - Testing a View [message #314812 is a reply to message #314752] Tue, 24 April 2007 12:25 Go to previous messageGo to next message
Swetha wrote:
> @Before
This is the part that won't work.
In your test, use IWorkbenchPage#findView("your.view.id") to get custView
Later,
PW
Re: Junit - Testing a View [message #314876 is a reply to message #314812] Thu, 26 April 2007 06:33 Go to previous messageGo to next message
Its not working,
I have placed the following ,
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().findView( "com.sequenom.everest.ui.CustomerView");
Still it getSite() and getViewSite() is null
Swetha
Re: Junit - Testing a View [message #314888 is a reply to message #314876] Thu, 26 April 2007 10:07 Go to previous messageGo to next message
Show us the snippet of code ... i.e. your setup and test ... the code
you wrote works fine when I run it :-)
PW
Re: Junit - Testing a View [message #314907 is a reply to message #314888] Fri, 27 April 2007 00:34 Go to previous messageGo to next message
The following is the method I am testing,
public void createWidget(Composite parent)
tree = new TreeViewer(parent, SWT.BORDER);
GlobalVariablesClass.modifier = new TreeCellModifier(tree);
tree.setCellModifier(GlobalVariablesClass.modifier);
tree.setColumnProperties(new String[] { "ProjectWidget" });
tree.setCellEditors(new CellEditor[] { new TextCellEditor(tree
.getTree()) });
// Adding Actions to context menu,Menubar and Toolbar
And the corresponding test method in JUnit is,
@Before
super.setUp();
@After
super.tearDown();
@Test
public void testGetTreeWidget()
The line getSite().setSelectionProvider(tree) , getSite() is coming as
null and causing NullPointerException
Swetha
Re: Junit - Testing a View [message #314918 is a reply to message #314907] Fri, 27 April 2007 07:19 Go to previous messageGo to next message
Swetha wrote:
> super.setUp();
I told you this wouldn't work.
What I mean is something like:
public void testGetTreeWidget() {
custView =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().showView( "com.sequenom.everest.ui.CustomerView");
Later,
PW
Re: Junit - Testing a View [message #314919 is a reply to message #314918] Fri, 27 April 2007 08:16 Go to previous message
got it .. Thank you very much...
Swetha
Previous Topic:Line number shown by default
Next Topic:Organize imports - Bug???
Current Time: Sun Oct 26 06:58:28 EDT 2025
Powered by FUDForum. Page generated in 0.05559 seconds
