Home » Eclipse Projects » Eclipse Platform » Problem with 3.3 Experimental Presentation
Problem with 3.3 Experimental Presentation [message #313218] Wed, 07 March 2007 14:54 Go to next message
Originally posted by: hotbbq.beast.homenetwork
I'm having an issue with search results. Whenever I select a search result,
it opens the result in the same tab as what I was previously looking at.
I have toggled the "Reuse editors to show matches" without any luck. Is there
another way to disable this behavior? It only happens in the experimental
presentation view.
Re: Problem with 3.3 Experimental Presentation [message #313219 is a reply to message #313218] Wed, 07 March 2007 15:19 Go to previous messageGo to next message
> presentation view.
I had my news reader configured improperly. The actual email address is
adbowers@gmail.com.
Re: Problem with 3.3 Experimental Presentation [message #313227 is a reply to message #313218] Thu, 08 March 2007 04:47 Go to previous messageGo to next message
Originally posted by: jakub.jurkiewicz.gmail.com
Which version of Eclipse do you use? 3.3? Can you reproduce the problem
with previous version of Eclipse?
I tried to find a bug for this in bugzilla, but without success.
Maybe you could create a bug and describe the error behavior?
regards,
Jakub Jurkiewicz
> presentation view.
Re: Problem with 3.3 Experimental Presentation [message #313309 is a reply to message #313227] Mon, 12 March 2007 16:57 Go to previous message
Originally posted by: bokowski.ca.ibm.com
This should not happen anymore. The experimental code to always reuse the
current editor tab was removed (I believe for M5).
Boris
"Jakub Jurkiewicz" <jakub.jurkiewicz@gmail.com> wrote in message
news:esom45$mof$1@utils.eclipse.org...
> regards,
> Jakub Jurkiewicz
>> result,
>> there
>> experimental
>> presentation view.
Previous Topic:double click listener on Common Navigator
Next Topic:[databinding] binding complex objects
Current Time: Fri Oct 24 17:31:00 EDT 2025
Powered by FUDForum. Page generated in 0.05877 seconds
