Home » Eclipse Projects » Eclipse Platform » Treeviewer select all the elements
Treeviewer select all the elements [message #312954] Mon, 26 February 2007 12:58 Go to next message
I would know if it's possible to select all the elements (all the
parents and all the children) in a treeviewer. Because I have tried to
use the following code :
mTreeViewer.getTree().selectAll();
But it seems not working. So there is a solution?
Many thanks in advance.
Re: Treeviewer select all the elements [message #312976 is a reply to message #312954] Mon, 26 February 2007 23:44 Go to previous messageGo to next message
Originally posted by: sateeshhegde.yahoo.co.in
I have used the following code and it works, not sure if there is any
other better solution.
treeView = new CheckboxTreeViewer(cmp, SWT.SINGLE);
treeView.addCheckStateListener(new ICheckStateListener() {
public void checkStateChanged(CheckStateChangedEvent event) {
// If the item is checked . . .
if (event.getChecked()) {
// . . . check all its children
treeView.setSubtreeChecked(event.getElement(), true);
}else {
// . . . uncheck all its children
treeView.setSubtreeChecked(event.getElement(), false);
Naiekko wrote:
Re: Treeviewer select all the elements [message #312980 is a reply to message #312954] Tue, 27 February 2007 02:59 Go to previous messageGo to next message
Naiekko wrote:
Have you ensured that your table has been created with the SWT.MULTI
flag? Otherwise the selectAll() method has no effect (as documented).
Greetings from Bremen,
Daniel Krügler
Re: Treeviewer select all the elements [message #312981 is a reply to message #312980] Tue, 27 February 2007 03:49 Go to previous message
Daniel Krügler a écrit :
> Naiekko wrote:
> Daniel Krügler
Yep I forgot to add the SWT.MULTI but I also forgot to add the
expandAll() method on the TreeViewer to have the selection for all the
elements.
Thanks a lot !
Previous Topic:Detecting end of POST_CHANGE?
Next Topic:Tool to translate externalized strings?
Current Time: Tue Jul 22 02:30:28 EDT 2025
Powered by FUDForum. Page generated in 0.03384 seconds
