Home » Archived » M2M (model-to-model transformation) » [ATL] find a target element by resolveTemp
[ATL] find a target element by resolveTemp [message #31548] Fri, 13 April 2007 13:38 Go to next message
Originally posted by: benoit.combemale.gmail.com
Hi all,
It is possible to find in a "matched rule" (A) a target model
element (by resolveTemp) created by a "called rule" called by
another "matched rule" (B) ?
thx,
Ben.
Benoît COMBEMALE
Re: [ATL] find a target element by resolveTemp [message #31584 is a reply to message #31548] Fri, 13 April 2007 14:56 Go to previous messageGo to next message
Originally posted by: mikael.barbero.gmail.com
Hi Ben,
No, it is not possible as called rule are not matched !! You must use
matched rule or lazy rule (restrictions exist in this case).
Mikael
Benoit Combemale wrote:
> Hi all,
> thx,
> Ben.
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] find a target element by resolveTemp [message #31618 is a reply to message #31584] Sat, 14 April 2007 09:10 Go to previous messageGo to next message
Hi Mikael,
Thx you for your response. In fact, my concrete problem is the fallowing :
rule A2B {
from MMa!A
to
..... -- target elements creation for all A
do {
if ( A.isXXX ) {
thisModule.myCalledRule(A) -- target elements creation when A is XXX
And now, i would like to find target elements created when A is XXX in another
rule.
Indeed, i can use two matched rule (A_WhichIsXXX2B and A_WhichIsNotXXX2B) but
i repeat all the common part :(
have you got some solutions ?
ben.
On Fri, 13 Apr 2007 20:56:23 +0200, Mikaël Barbero <mikael.barbero@gmail.com> wrote :
> Hi Ben,
> Mikael
>> Hi all,
>> thx,
>> Ben.
Benoît COMBEMALE
Re: [ATL] find a target element by resolveTemp [message #31653 is a reply to message #31618] Sat, 14 April 2007 11:06 Go to previous messageGo to next message
Thx you for your help Mikael.
I resolve my problem by the use of rule inheritance.
Ben.
On Sat, 14 Apr 2007 15:10:06 +0200, Benoit Combemale <benoit.combemale@gmail.com> wrote :
> Hi Mikael,
> rule A2B {
> from MMa!A
> to
> do {
> if ( A.isXXX ) {
> rule.
> ben.
>> Hi Ben,
>> Regards,
>> Mikael
>>> Hi all,
>>> thx,
>>> Ben.
Benoît COMBEMALE
Re: [ATL] find a target element by resolveTemp [message #32215 is a reply to message #31584] Tue, 17 April 2007 02:25 Go to previous messageGo to next message
which are the restrictions on resolveTemp when the target element
is created by one lazy rule ?
Thx
ben.
> Hi Ben,
> Mikael
>> Hi all,
>> thx,
>> Ben.
Benoît COMBEMALE
Re: [ATL] find a target element by resolveTemp [message #32250 is a reply to message #32215] Tue, 17 April 2007 03:57 Go to previous messageGo to next message
Hi Benoit,
I'm glad to see that you solved your problem.
There are restrictions when you have multiple lazy rules matching the
same model element: ATL is not able to determine which one has to be
selected.
Mikael
> Thx
> ben.
>> Hi Ben,
>> Regards,
>> Mikael
>>> Hi all,
>>> thx,
>>> Ben.
Re: [ATL] find a target element by resolveTemp [message #32533 is a reply to message #32250] Wed, 18 April 2007 09:51 Go to previous messageGo to next message
Hi Mikael,
In my work, I've one lazy rule called by one matched rule (A).
In another matched rule (B), I try to find the target element created
by the lazy rule.
I've an execution error :
"message: ERROR: could not find operation including on Module
having supertypes: [OclAny]"
Have you got an example with a lazy rule called by a first matched rule
and a second matched rule which use resolveTemp to find the target element
created by the lazy rule ?
Ben.
On Tue, 17 Apr 2007 09:57:30 +0200, Mikaël Barbero <mikael.barbero@gmail.com> wrote :
> Hi Benoit,
> selected.
> Mikael
>> Thx
>> ben.
>>> Hi Ben,
>>> Regards,
>>> Mikael
>>>> Hi all,
>>>> thx,
>>>> Ben.
Benoît COMBEMALE
Re: [ATL] find a target element by resolveTemp [message #34709 is a reply to message #32533] Fri, 27 April 2007 11:07 Go to previous message
Hello Benoit,
It is possible that resolveTemp does not always work correctly with lazy
rules, I will have to look into this.
However, there is a relatively simple way to make this work: splitting
the lazy rule (see example below).
If you have something like:
rule A {
from
s : MMa!A
to
t : MMb!A (
b <- thisModule.B(s.b),
-- may not work, and apparently does not
-- work in your case
c <- thisModule.resolveTemp(s.b, 't2')
-- Note that referring to several target elements of a lazy rule
-- mostly makes sense when this rule is *unique*, otherwise it would
-- mean invoking the rule once again.
unique lazy rule B {
from
s : MMa!B
to
t : MMb!B (
c <- t2
t2 : MMb!C
You may rewrite it into:
rule A {
from
s : MMa!A
to
t : MMb!A (
b <- thisModule.B_1(s.b),
c <- thisModule.B_2(s.b)
unique lazy rule B_1 { -- or B2B
from
s : MMa!B
to
t : MMb!B (
c <- thisModule.B_2(s)
unique lazy rule B_2 { -- or B2C
from
s : MMa!B
to
t : MMb!C
Frédéric Jouault
> Hi Mikael,
> by the lazy rule.
> Ben.
>> Hi Benoit,
>> selected.
>> Regards,
>> Mikael
>>> Thx
>>> ben.
>>>> Hi Ben,
>>>> Regards,
>>>> Mikael
>>>>> Hi all,
>>>>> thx,
>>>>> Ben.
Previous Topic:[ATL] problem with generating Ecore DataTypes
Next Topic:[ATL] need to do a calcul one Time
Current Time: Sat Jun 07 05:19:26 EDT 2025
Powered by FUDForum. Page generated in 0.03522 seconds
