Home » Eclipse Projects » SWTBot » Extra space needed in name to find a menu item
Extra space needed in name to find a menu item [message #31525] Mon, 06 April 2009 11:08 Go to next message
Hi Ketan.
We are experiencing some strange behaviour when we try to find a menu item
in the "Edit" menu in the main menu. On my machine the following lines of
code works fine:
final SWTBotMenu editMenu = bot.menu("Edit");
editMenu.menu("Undo").click();
However, this code throws a "WidgetNotFoundException" on my colleagues
machine. He needs to add an extra space in the name of the undo menu item.
Like this:
editMenu.menu("Undo ").click();
Of course this now throws a "WidgetNotFoundException" on my machine. We are
both running on the same version of Eclipse (3.4.2) with the same version of
SWTBot (2.0.0.204-dev).
What are we doing wrong?
Anders
Re: Extra space needed in name to find a menu item [message #31561 is a reply to message #31525] Mon, 06 April 2009 11:39 Go to previous messageGo to next message
Hi Anders,
Not sure what's wrong. Perhaps turning on logging[1] will print you
detailed level information about the widgets swtbot finds, and the ones
it matches.
Looking at the WithMnemonic matcher[2], which is used to match the text
on menu items, it does not seem to do any trimming of strings that could
mess things up.
[1] -
http://wiki.eclipse.org/SWTBot/FAQ#How_do_I_configure_log4j_ to_turn_on_logging_for_SWTBot.3F
[2] -
http://github.com/ketan/swtbot/blob/master/org.eclipse.swtbo t.swt.finder/src/org/eclipse/swtbot/swt/finder/matchers/With Mnemonic.java
-- Ketan
On 6/4/09 20:38, Anders Baumann wrote:
> Hi Ketan.
> code works fine:
> Like this:
> Best regards,
> Anders
Re: Extra space needed in name to find a menu item [message #31591 is a reply to message #31561] Wed, 08 April 2009 08:34 Go to previous message
As the undo action is a retarget action it allows for setting the label
dynamically to the operation. I would guess you clicked two different
operations one having an additional label and the other has not.
Maybe it is a starting point for you to dig in.
Jens
Previous Topic:SWTBot application and plugin
Next Topic:Use regular expression for selection
Current Time: Thu Jul 17 09:46:19 EDT 2025
Powered by FUDForum. Page generated in 0.03261 seconds
