Home » General (non-technical) » Eclipse Foundation » Upgrade Woes 3.1.0 to 3.1.2
Upgrade Woes 3.1.0 to 3.1.2 [message #31443] Sat, 11 March 2006 22:28 Go to next message
Hope someone can help me here. I have an existing 3.1.0 Eclipse setup that
I tried to upgrade to 3.1.2 using the upgrade tool and following the
instructions given here:
http://www.eclipse.org/eclipse/platform-releng/updatesfor3.1 .1.html
All seemed to go well until the installer asked for permission to restart
Eclipse. Upon restart, I get the splash screen, and then an error window
directing me to the .log file.
I believe this is the pertinent part of that log:
!SESSION 2006-03-11
21:07:48.315 -----------------------------------------------
eclipse.buildId=I20050610-1757
java.version=1.5.0_03
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2006-03-11 21:07:50.190
!MESSAGE Application error
!STACK 1
java.lang.IncompatibleClassChangeError
org.eclipse.ui.internal.ide.ChooseWorkspaceData.readPersiste dData(ChooseWorkspaceData.java:366)
org.eclipse.ui.internal.ide.ChooseWorkspaceData.<init>(ChooseWorkspaceData.java:108)
org.eclipse.ui.internal.ide.IDEApplication.checkInstanceLoca tion(IDEApplication.java:220)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:90)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
I have done quite a bit of Googling, etc and can find no solution. I have
downloaded the 3.1.2 SDK and installed it. It will come up okay, and will
import my workspace (with numerous compile problems because all of my
library definitions, extra plugins, etc aren't there.) I really would like
to fix the broken 3.1.0 upgrade to avoid a lot of recovery work.
Can anyone help? Thanks.
Re: Upgrade Woes 3.1.0 to 3.1.2 [message #31486 is a reply to message #31443] Sun, 12 March 2006 00:25 Go to previous message
Just realized I posted this to an inappropriate group. I have reposted it
in eclipse.platform, please ignore this entry...but please respond to the
properly placed one :-)
"John Neal" <johnneal@knology.net> wrote in message
news:dv04ih$meq$1@utils.eclipse.org...
> that I tried to upgrade to 3.1.2 using the upgrade tool and following the
> !SESSION 2006-03-11
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 1
> at
> at
> at
> at
> at
> at
> like to fix the broken 3.1.0 upgrade to avoid a lot of recovery work.
Previous Topic:install xerces plugin
Next Topic:EclipseCon 2006 Almost Sold-Out
Current Time: Thu Jul 17 19:59:25 EDT 2025
Powered by FUDForum. Page generated in 0.05250 seconds
