Is it possible to modify the position of Diagram menu on main menu bar? [message #2718] |
Thu, 03 August 2006 02:15  |
Originally posted by: tiggo.kan.gmail.com
// copy from old newsgroup
The default "menu path" is "/project", it will cause a problem when
deploy to RCP, where may NO "/project" group marker on menu bar.
Below is something I found in rumtime diagram module, just FYI:
In "org.eclipse.gmf.runtime.diagram.ui.providers", diagram menu was
defined as:
<extension id="presentationContributionItemProvider"
name="%ext.presentationContributionItemProvider"
point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
<partContribution
class=" org.eclipse.gmf.runtime.diagram.ui.parts.IDiagramWorkbenchPa rt ">
<partMenu menubarPath="/project" id="diagramMenu"/>
that is, just after the "project" group marker, it will cause some
problem...
If I deploy gmf as RCP, that is, there maybe no "project" group marker.
So I have to modify the registed "menu path". Unfortunely, it seems hard
to achieve it...
Any idea on it?
also find the previous discussion as below.
regards / tiggo
> Cherie Mahoney wrote:
> Henrik,
> You can contribute an action to this menu using the Contribution Item
> Service or the org.eclipse.ui.editorActions extension point (in
theory, but
> I've never tested it). The Contribution Item Service is GMF's way of
> extending the Eclipse menu support to provide additional behavior we
wanted
> (e.g. menu item hiding). GMF contributes to the Diagram menu using the
> Contribution Item Service, but you should be able to use either mechanism
> (although menu ordering may be tricky). Maybe someday the
Contribution Item
> Serice enhancements will be merged into the Eclipse menu support so
you may
> want to stick with the Eclipse menu extension mechanism if that is
what you
> are currently using and if provides you with the behavior you want.
> The menu id is "diagramMenu". It is defined in
> org.eclipse.gmf.runtime.diagram.ui.providers\plugin.xml. You won't
be able
> to rename it, but you could add your own menu to the main menu bar.
> For an example of using the ContributionItemService see the GMF Logic
> Example. It does not contribute to the main diagram menu though.
Look in
> org.eclipse.gmf.runtime.diagram.ui.providers\plugin.xml for an example of
> this.
> e.g. <partAction menubarPath="/diagramMenu/sizeGroup"
> toolbarPath="/toolbarFormatGroup" id="autoSizeAction"></partAction>
> - Cherie
> "Henrik Rentz-Reichert" <hrr@protos.de> wrote in message
> news:dknb73$fb4$1@news.eclipse.org...
>> how can I make contributions to the Diagram menu from the main menu bar?
>> Is it possible to change the name of this menu?
>> Thanks,
>> Henrik
>> Henrik Rentz-Reichert mailto://hrr@protos.de
Re: Is it possible to modify the position of Diagram menu on main menu bar? [message #6379 is a reply to message #6361] |
Thu, 03 August 2006 21:51  |
Hi Linda,
If I want to specify the "menu path", such as "/edit", possible?
btw, I have tried a workaround, by adding "/project" group mark after
"edit" menu when configure the RCP workbench. Strangely, it have
problem; diagram menu will dispeared, when open another diagram editor
(I have two types of editor), though it's OK on the first diagram editor.
regards / tiggo
Linda Damus wrote:
> Oops, I lost track of which newsgroup I was reading when I replied to
> this earlier. Here's what I meant to say here...
> Hi Tiggo,
> I would have expected the diagram menu to show up in the "additions"
> part of the menu if the "project" group marker can't be found. Is that
> not the case?
> Linda
FUDForum. Page generated in 0.06620 seconds
