Hot key can't work! [message #310431] |
Sat, 02 December 2006 12:12  |
hi,
Recently, I downloaded the newest Eclipse v3.2.1, but Ctrl + Alt + Up/Down
can't work properly!
The type of My notebook is ThinkPad X60s.
Can anyone provide some direction for troubleshooting?
Thanks for any help you can give.
Re: Hot key can't work! [message #310608 is a reply to message #310606] |
Mon, 11 December 2006 12:32  |
no problem with the newest jdk 6!
Thanks a lot!
"xldelphi" <xldelphi@gmail.com> wrote in message
news:elk1qs$m9a$1@utils.eclipse.org...
> Thanks for your answer.
> As local test, the keys are being trapped properly by windows sdk in
> windows xp + sp2,
> but can't be trapped by jdk1.5.0_9(without swt). I think it seem to be a
> bug of j2se.
> "John J. Barton" <johnjbarton@johnjbarton.com> wrote in message
> news:elesga$qi$1@utils.eclipse.org...
>> To determine if the keys are being trapped before they get to eclipse
>> you can run a simple Java application to print the keys you press. See
>> for example
>> http://www.java2s.com/Code/JavaAPI/org.eclipse.swt.widgets/T extaddKeyListenerKeyListenerlis.htm
>> or
>> http://www.cs.umanitoba.ca/~eclipse/2-Basic.pdf
>> If such a program prints normal keys but not C-A-Up, then chances are
>> good that the OS or BIOS gets them first.
>>> but the setting of eclipse is default.
>>> news:ektgcs$o02$1@utils.eclipse.org...
>>>> Any chance you have used "customize perspective" to remove toolbar
>>>> buttons? To my surprise removing buttons also removes keybindings!
>>>> John.
>>>> xldelphi wrote:
>>>>> hi,
>>>>> Up/Down can't work properly!
FUDForum. Page generated in 0.05584 seconds
