Home » Eclipse Projects » Eclipse Platform » CompareUI.openCompareDialog
CompareUI.openCompareDialog [message #310022] Wed, 15 November 2006 21:49 Go to next message
Forgive my newbie-ness, but is this the correct group to post a question
on the CompareUI functionality?
I've been trying to get the CompareDialog to work when passed a
CompareEditorInput containing a CompareNode that implements
IEditableContent (i.e. allows saving of data from within the compare dialog)
I've found what I think are a couple of bugs, around when you press the
Commit button to save the changes made. Basically it doesn't
instantiate a progress monitor correctly for the corresponding
WorkspaceModificationOperation and also it doesn't actually pass the
contents of the modified part to the CompareNode (due to the dialog
parts having been already disposed by the time the save method is being
processed). CompareEditor works just great however.
Anyway, I was wanting to have a chat with the appropriate folks first to
make sure I wasn't being really dumb before I create a bug and submit a
patch.
If this is the wrong group, but you happen to know where the clever
compare folks hang out then please let me know.
Many thanks,
Martin.
Re: CompareUI.openCompareDialog [message #310032 is a reply to message #310022] Thu, 16 November 2006 11:03 Go to previous messageGo to next message
Martin,
I discovered this a few weeks ago as well and have released a fix to
3.3. You will need the latest I-build to get the fix.
Michael
> patch.
> Many thanks,
> Martin.
Re: CompareUI.openCompareDialog [message #310035 is a reply to message #310032] Thu, 16 November 2006 15:28 Go to previous message
Fantastic - thanks Michael. In the end I just rolled my own
CompareDialog with my fixes incorporated so that it will work in Eclipse
3.0 and up (the joys of supporting RAD :-) ) - but I'll go take a look
at the fixes you made to see what I should have done..
Glad to see I wasn't going totally crazy :-)
M.
Michael Valenta wrote:
> Martin,
> Michael
>> dialog)
>> patch.
>> Many thanks,
>> Martin.
Previous Topic:Clicking Link in Stack Trace does not open source file
Next Topic:IResourceDeta.COPIED_FROM usage
Current Time: Sun Jul 27 00:33:15 EDT 2025
Powered by FUDForum. Page generated in 0.05457 seconds
