Home » Eclipse Projects » Eclipse Platform » Problem invoking static methods.
Problem invoking static methods. [message #309787] |
Wed, 08 November 2006 17:49  |
Originally posted by: jpk4077.hotmail.com
------=_NextPart_000_0276_01C7035E.3411CF20
Content-Type: text/plain;
charset="iso-8859-1"
I am not sure why but I am not able to invoke a static function from =
within a popupmenu plugin. common is another package in the same plugin =
project. I am attaching the code where I am invoking a static function =
of another class Utils. The output only shows "BEFORE".
On debug, earlier eclipse showed me a class not found error, now it does =
not show me anything. I have done a project clean and a full compile and =
the class files are present in the right directory.
Tx Praveen.
package common;
public class Utils {
public static void writeToFile(String str, String fileLocation,
String fileName) {
System.out.println("INSIDE..." + str + " :: " + fileName);
package plugin.actions;
import org.eclipse.core.resources.IContainer;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IProject;
import org.eclipse.core.resources.IResource;
import org.eclipse.core.resources.IncrementalProjectBuilder;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.IStructuredSelection;
import org.eclipse.ui.IActionDelegate;
import org.eclipse.ui.IObjectActionDelegate;
import org.eclipse.ui.IWorkbenchPart;
public class ConvertAction implements IObjectActionDelegate {
public void run(IAction action) {
if (!m_Selection.isEmpty()) {
IStructuredSelection sel =3D (IStructuredSelection) =
m_Selection;
Object obj =3D sel.getFirstElement();
if (obj instanceof IFile) {
IFile file =3D (IFile) obj;
IContainer cont =3D file.getParent();
String fileName =3D file.getName();
String location =3D file.getLocation().toOSString();
String fileDir =3D location.substring(0, =
location.length()
- fileName.length() - 1);
String str =3D "TEXT";
System.out.println("BEFORE");
Utils.writeToFile(str, fileDir, "MyFile.txt");
System.out.println("AFTER");
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1476" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>Hi,</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2></FONT> </DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>I am not sure why but =
I am not able=20
to invoke a static function from within a popupmenu plugin. common is =
another=20
package in the same plugin project. I am attaching the code where I am =
invoking=20
a static function of another class Utils. The output only shows=20
"BEFORE".</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>On debug, earlier =
eclipse showed me=20
a class not found error, now it does not show me anything. I have done a =
project=20
clean and a full compile and the class files are present in the right=20
directory.</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>Tx =
Praveen.</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000080=20
size=3D2>---------------------------------</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>package =
common;</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>public class Utils=20
{<BR> public static void writeToFile(String str, =
String=20
fileLocation,<BR> &n=
bsp; =20
String fileName) {<BR> =20
System.out.println("INSIDE..." + str + " :: " + =
fileName);<BR> =20
}<BR>}</FONT></DIV>
plugin.actions;<BR>import=20
org.eclipse.core.resources.IContainer;<BR>import=20
org.eclipse.core.resources.IFile;<BR>import=20
org.eclipse.core.resources.IProject;<BR>import=20
org.eclipse.core.resources.IResource;<BR>import=20
org.eclipse.core.resources.IncrementalProjectBuilder;<BR>import=20
org.eclipse.core.runtime.CoreException;<BR>import=20
org.eclipse.jface.action.IAction;<BR>import=20
org.eclipse.jface.viewers.ISelection;<BR>import=20
org.eclipse.jface.viewers.IStructuredSelection;<BR>import=20
org.eclipse.ui.IActionDelegate;<BR>import=20
org.eclipse.ui.IObjectActionDelegate;<BR>import=20
org.eclipse.ui.IWorkbenchPart;</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>public class =
ConvertAction=20
implements IObjectActionDelegate {<BR> public void =
run(IAction=20
action) {<BR> if=20
(!m_Selection.isEmpty())=20
{<BR> =20
IStructuredSelection sel =3D (IStructuredSelection)=20
m_Selection;<BR> &nb=
sp; =20
Object obj =3D=20
sel.getFirstElement();<BR>  =
; =20
if (obj instanceof IFile)=20
{<BR> &n=
bsp; =20
IFile file =3D (IFile)=20
obj;<BR>  =
; =20
IContainer cont =3D=20
file.getParent();<BR> &nbs=
p; &nbs p;=20
String fileName =3D=20
file.getName();<BR> =
=20
String location =3D=20
file.getLocation().toOSString();<BR> &=
nbsp; & nbsp; =20
String fileDir =3D location.substring(0,=20
location.length()<BR> &nbs=
p; &nbs p; &nbs p=
; =20
- fileName.length() -=20
1);<BR> =
=20
String str =3D=20
"TEXT";<BR>System.out.println("BEFORE");<BR>  =
=20
Utils.writeToFile(str, fileDir,=20
"MyFile.txt");<BR>System.out.println("AFTER");<BR>  =
;   ; =20
}<BR> }<BR> =20
}<BR> }<BR>}</FONT></DIV>
size=3D2>---------------------------------</FONT></DIV></BODY ></HTML>
------=_NextPart_000_0276_01C7035E.3411CF20--
Re: Problem invoking static methods. [message #309788 is a reply to message #309787] |
Wed, 08 November 2006 17:55   |
------=_NextPart_000_0285_01C7035F.1FD7EED0
I am able to invoke the static method from a regular class as follows. =
So the eclipse JDK has the class path etc. setup. I suspect its some =
tweak I need to make in the plugin execution environment.
Thanks Praveen.
import common.Utils;
public class asd {
Utils.writeToFile("A", "C:\\ad", "QWE.txt");
"Praveen" <jpk4077@hotmail.com> wrote in message =
news:eitmt9$lvs$1@utils.eclipse.org...
On debug, earlier eclipse showed me a class not found error, now it =
does not show me anything. I have done a project clean and a full =
compile and the class files are present in the right directory.
Tx Praveen.
package common;
String fileName) {
m_Selection;
location.length()
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV>I am able to invoke the static method from a regular class as =
follows. So=20
the eclipse JDK has the class path etc. setup. I suspect its some tweak =
I need=20
to make in the plugin execution environment.</DIV>
<DIV> </DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>Thanks =
<DIV> </DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>import =
common.Utils;</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>public class asd =
{</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2> =
public static=20
void main(String[] args) {<BR> =
Utils.writeToFile("A", "C:\\ad", "QWE.txt");<BR> =20
}<BR>}<BR></FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
BORDER-LEFT: #000080 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Praveen" <<A=20
href=3D"mailto:jpk4077@hotmail.com">jpk4077@hotmail.com</A>> wrote =
in message=20
<A=20
href=3D"news:eitmt9$lvs$1@utils.eclipse.org">news:eitmt9$lvs$1@utils.ecli=
pse.org</A>...</DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>I am not sure why =
but I am not=20
able to invoke a static function from within a popupmenu plugin. =
common is=20
another package in the same plugin project. I am attaching the code =
where I am=20
invoking a static function of another class Utils. The output only =
shows=20
eclipse showed=20
me a class not found error, now it does not show me anything. I have =
done a=20
project clean and a full compile and the class files are present in =
the right=20
String=20
bsp; =20
System.out.println("INSIDE..." + str + " :: " +=20
fileName);<BR> }<BR>}</FONT></DIV>
ConvertAction=20
implements IObjectActionDelegate {<BR> public void=20
run(IAction action) {<BR> if =
{<BR> =20
sp; =20
Object obj =3D=20
; =20
{<BR> &n=
bsp; =20
obj;<BR>  =
; =20
p; &nbs p;=20
=20
nbsp; & nbsp; =20
p; &nbs p; &nbs p=
; =20
1);<BR> =
=20
String str =3D=20
=20
;   ; =20
}<BR> =
}<BR> =20
size=3D2>---------------------------------</FONT></DIV></BLOCKQUOTE ></BOD=
Y></HTML>
------=_NextPart_000_0285_01C7035F.1FD7EED0--
Re: Problem invoking static methods. [message #309790 is a reply to message #309788] |
Wed, 08 November 2006 20:25   |
> Thanks Praveen.
> public class asd {
> public static void main(String[] args) {
> "Praveen" <jpk4077@hotmail.com <mailto:jpk4077@hotmail.com>> wrote
> in message news:eitmt9$lvs$1@utils.eclipse.org...
> plugin project. I am attaching the code where I am invoking a static
> function of another class Utils. The output only shows "BEFORE".
> Tx Praveen.
> package common;
> String fileName) {
> IStructuredSelection sel = (IStructuredSelection)
> m_Selection;
> Object obj = sel.getFirstElement();
> IFile file = (IFile) obj;
> IContainer cont = file.getParent();
> String fileName = file.getName();
> String location = file.getLocation().toOSString();
> String fileDir = location.substring(0, location.length()
> String str = "TEXT";
I notice that your code doesn't include an import for common.Utils. Is
this just a cut and paste omission?
Re: Problem invoking static methods. [message #309791 is a reply to message #309790] |
Wed, 08 November 2006 22:43   |
------=_NextPart_000_034F_01C70387.5B3F1E80
Yes, I apologize for the typo.
~Praveen.
"David Wegener" <wegener@cboenospam.com> wrote in message =
news:eiu033$csi$2@utils.eclipse.org...
follows.=20
> =20
> Thanks Praveen.
> =20
> =20
> public class asd {
> =20
>=20
> "Praveen" <jpk4077@hotmail.com <mailto:jpk4077@hotmail.com>> =
> =20
> I am not sure why but I am not able to invoke a static function =
from
> plugin project. I am attaching the code where I am invoking a =
static
> =20
> On debug, earlier eclipse showed me a class not found error, now =
it
> does not show me anything. I have done a project clean and a =
full
> =20
> Tx Praveen.
> package common;
> =20
> public static void writeToFile(String str, String =
fileLocation,
> String fileName) {
fileName);
> =20
> m_Selection;
> String location =3D =
location.length()
> Utils.writeToFile(str, fileDir, =
"MyFile.txt");
I notice that your code doesn't include an import for common.Utils. =
Is=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>Yes, I apologize for =
the=20
typo.</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000080 =
size=3D2>~Praveen.</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"David Wegener" <<A=20
href=3D"mailto:wegener@cboenospam.com">wegener@cboenospam.com</A>> =
wrote in=20
message <A=20
href=3D"news:eiu033$csi$2@utils.eclipse.org">news:eiu033$csi$2@utils.ecli=
pse.org</A>...</DIV>Praveen=20
wrote:<BR>> I am able to invoke the static method from a regular =
class as=20
follows. <BR>> So the eclipse JDK has the class path etc. setup. I =
suspect=20
its some <BR>> tweak I need to make in the plugin execution=20
environment.<BR>> <BR>> Thanks Praveen.<BR>> =
<BR>>=20
import common.Utils;<BR>> <BR>> public class asd =
{<BR>> =20
<BR>> public static void main(String[] =
args)=20
{<BR> > &a mp;nbsp; =20
Utils.writeToFile("A", "C:\\ad", =
"QWE.txt");<BR>> =20
}<BR>> }<BR>> <BR>> "Praveen" <<A=20
href=3D"mailto:jpk4077@hotmail.com">jpk4077@hotmail.com</A> <<A=20
href=3D"mailto:jpk4077@hotmail.com">mailto:jpk4077@hotmail.com</A>>>=
;=20
wrote<BR>> in message <A=20
pse.org</A>...<BR>> =20
Hi,<BR>> =
<BR>> I=20
am not sure why but I am not able to invoke a static function=20
from<BR>> within a popupmenu plugin. common =
is=20
another package in the same<BR>> plugin =
project. I=20
am attaching the code where I am invoking a=20
static<BR>> function of another class =
Utils. The=20
output only shows "BEFORE".<BR> > =2 0
<BR>> On debug, earlier eclipse showed me a =
class=20
not found error, now it<BR>> does not show =
me=20
anything. I have done a project clean and a=20
full<BR>> compile and the class files are =
present=20
in the right directory.<BR> > =2 0
<BR>> Tx =
Praveen.<BR>> =20
---------------------------------<BR>> =
package=20
common;<BR>> =
<BR>> =20
public class Utils =
public static void writeToFile(String str, String=20
fileLocation,<BR> > &a mp;nbsp; &nbs=
p; &nbs p; =20
String fileName)=20
{<BR> > &a mp;nbsp; &nbs=
p; =20
fileName);<BR> > &a mp;nbsp; =20
}<BR>> }<BR>> =20
package=20
plugin.actions;<BR>> import=20
org.eclipse.core.resources.IContainer;<BR>> =
import=20
org.eclipse.core.resources.IFile;<BR>> =
import=20
org.eclipse.core.resources.IProject;<BR>> =
import=20
org.eclipse.core.resources.IResource;<BR>> =
import=20
org.eclipse.core.resources.IncrementalProjectBuilder;<BR>> =
=20
import =
org.eclipse.core.runtime.CoreException;<BR>> =20
import =
org.eclipse.jface.action.IAction;<BR>> =20
import =
org.eclipse.jface.viewers.ISelection;<BR>> =20
import=20
org.eclipse.jface.viewers.IStructuredSelection;<BR>> =
=20
import org.eclipse.ui.IActionDelegate;<BR>> =
import=20
org.eclipse.ui.IObjectActionDelegate;<BR>> =
import=20
org.eclipse.ui.IWorkbenchPart;<BR> > =2 0
<BR>> public class ConvertAction implements =
IObjectActionDelegate=20
{<BR> > &a mp;nbsp; public void=20
run(IAction action)=20
p; =20
if (!m_Selection.isEmpty())=20
p; =20
IStructuredSelection sel =3D=20
(IStructuredSelection)<BR>> =20
m_Selection;<BR> > &a mp;nbsp;  =
;   ; =20
Object obj =3D=20
sel.getFirstElement();<BR> > &a mp;nbsp; &=
nbsp; & nbsp; =20
p; &nbs p; =20
obj;<BR> > &a mp;nbsp; &=
nbsp; & nbsp; =20
file.getParent();<BR> > &a mp;nbsp; =
file.getName();<BR> > &a mp;nbsp; &n=
bsp; &n bsp; =20
file.getLocation().toOSString();<BR> > &a mp;nb=
sp; &nb sp; &nb s=
p; =20
location.length()<BR> > &a mp;nbsp; =
nbsp; & nbsp; =20
1);<BR> > &a mp;nbsp; &n=
bsp; &n bsp; =20
String str =3D "TEXT";<BR>> =20
System.out.println("BEFORE");<BR> > &a mp;nbsp;=
nbsp; =20
"MyFile.txt");<BR>> =20
System.out.println("AFTER");<BR> > &a mp;nbsp;&=
nbsp; & nbsp; =20
}<BR> > &a mp;nbsp; &nbs=
p; =20
}<BR> > &a mp;nbsp; =20
}<BR> > &a mp;nbsp;=20
}<BR>> }<BR>> =20
---------------------------------<BR>I notice that your code doesn't =
include=20
an import for common.Utils. Is <BR>this just a cut and paste=20
omission?</BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_034F_01C70387.5B3F1E80--
Re: Problem invoking static methods. [message #309792 is a reply to message #309791] |
Thu, 09 November 2006 01:48   |
------=_NextPart_000_03C2_01C703A1.38DD8C90
I suspect its because the plugin is in package plugin.actions and the =
utils class is in common package. common and plugin are at the same =
hierarchy but the execution considers plugin.action as the root and =
looks for common.utils inside it.
I tried adding the bin and src directories to classpath in the runtime =
tab but that doesent help. Any other ideas?
Thanks Praveen.
news:eiu85n$ah4$1@utils.eclipse.org...
~Praveen.
follows.=20
> So the eclipse JDK has the class path etc. setup. I suspect its =
some=20
> =20
> Thanks Praveen.
> =20
> =20
> public class asd {
> =20
>=20
> =20
> I am not sure why but I am not able to invoke a static =
function from
> within a popupmenu plugin. common is another package in the =
same
static
> function of another class Utils. The output only shows =
"BEFORE".
> =20
> On debug, earlier eclipse showed me a class not found error, =
now it
full
> compile and the class files are present in the right =
directory.
> =20
> Tx Praveen.
> package common;
> =20
fileLocation,
> String fileName) {
fileName);
> =20
> IStructuredSelection sel =3D =
> m_Selection;
location.length()
"MyFile.txt");
Is=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>I suspect its because =
the plugin is=20
in package plugin.actions and the utils class is in common package. =
common and=20
plugin are at the same hierarchy but the execution considers =
plugin.action as=20
the root and looks for common.utils inside it.</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>I tried adding the =
bin and src=20
directories to classpath in the runtime tab but that doesent help. Any =
other=20
ideas?</FONT></DIV>
in message=20
<A=20
href=3D"news:eiu85n$ah4$1@utils.eclipse.org">news:eiu85n$ah4$1@utils.ecli=
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>Yes, I apologize =
for the=20
typo.</FONT></DIV>
<BLOCKQUOTE=20
wrote in=20
message <A=20
class as=20
follows. <BR>> So the eclipse JDK has the class path etc. setup. =
I=20
suspect its some <BR>> tweak I need to make in the plugin =
execution=20
<BR>>=20
{<BR>> =20
args)=20
}<BR>> }<BR>> <BR>> "Praveen" =
<<A=20
;=20
Hi,<BR>> =
<BR>> I=20
from<BR>> within a popupmenu plugin. =
common is=20
project.=20
I am attaching the code where I am invoking a=20
Utils. The=20
<BR>> On debug, earlier eclipse showed me =
a class=20
not found error, now it<BR>> does not =
show me=20
present=20
<BR>> Tx =
Praveen.<BR>> =20
package=20
common;<BR> > =2 0
<BR>> public class Utils=20
{<BR> > &a mp;nbsp; public =
static void=20
p; &nbs p; =20
String fileName)=20
p; =20
}<BR>> }<BR>> =20
package=20
org.eclipse.core.resources.IContainer;<BR>> =20
import =
org.eclipse.core.resources.IFile;<BR>> =20
import =
org.eclipse.core.resources.IProject;<BR>> =20
import =
org.eclipse.core.resources.IResource;<BR>> =20
import=20
=20
import=20
import =
import =
import=20
=20
import =
org.eclipse.ui.IActionDelegate;<BR>> =20
import =
org.eclipse.ui.IObjectActionDelegate;<BR>> =20
import =
<BR>> public class ConvertAction =
implements=20
void=20
p; =20
p; =20
;   ; =20
Object obj =3D=20
nbsp; & nbsp; =20
p; &nbs p; =20
nbsp; & nbsp; =20
bsp; &n bsp; =20
sp; &nb sp; &nb s=
p; =20
nbsp; & nbsp; =20
bsp; &n bsp; =20
nbsp; =20
nbsp; & nbsp; =20
p; =20
}<BR>> }<BR>> =20
include=20
omission?</BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_03C2_01C703A1.38DD8C90--
Re: Problem invoking static methods. [message #309806 is a reply to message #309792] |
Thu, 09 November 2006 10:13   |
Praveen,
in the OSGi runtime, your plugin.actions bundle can only load classes
from bundles that it said it required.
What you need to do is for the common bundle to add an Export-Package
for its utils package in its manifest.mf file.
Then plugin.actions needs to either Require-Bundle: common, or
Import-Package: common.utils in its manifest.
-Andrew
> Thanks Praveen.
> in message news:eiu85n$ah4$1@utils.eclipse.org...
> ~Praveen.
> <mailto:wegener@cboenospam.com>> wrote in message
> follows.
> its some
> > Thanks Praveen.
> > public class asd {
> > Hi,
> function from
> the same
> invoking a static
> "BEFORE".
> error, now it
> and a full
> directory.
> > Tx Praveen.
> > package common;
> fileLocation,
> > String fileName) {
> fileName);
> > m_Selection;
> > String location =
> location.length()
> "MyFile.txt");
> common.Utils. Is
Re: Problem invoking static methods. [message #309881 is a reply to message #309806] |
Fri, 10 November 2006 12:11  |
------=_NextPart_000_017B_01C704C1.600F1970
Hi Andrew,
I made another hello world plugin with just the same hierarchy of plugin =
and other classes and I am able to access the plugin static method =
without doing an export-Package or a required-Bundle.=20
In my existing project with common, plugin.actions, I added in the =
exported packages tab and the classpath tab. But am still facing the =
same problem
I am not sure what I am missing.
Tx Praveen.
"Andrew Niefer" <aniefer@ca.ibm.com> wrote in message =
news:eivgh2$spj$1@utils.eclipse.org...
Praveen,
in the OSGi runtime, your plugin.actions bundle can only load classes=20
What you need to do is for the common bundle to add an Export-Package=20
Then plugin.actions needs to either Require-Bundle: common, or=20
-Andrew
Praveen wrote:
> I suspect its because the plugin is in package plugin.actions and =
the=20
> utils class is in common package. common and plugin are at the same=20
> hierarchy but the execution considers plugin.action as the root and=20
> =20
> I tried adding the bin and src directories to classpath in the =
runtime=20
> =20
> Thanks Praveen.
>=20
> =20
> ~Praveen.
>=20
class as
> follows.
suspect
> its some
> >=20
> > Thanks Praveen.
> >=20
> >=20
> > public class asd {
> >=20
> <mailto:jpk4077@hotmail.com> <mailto:jpk4077@hotmail.com>> =
> > Hi,
> > =20
> > I am not sure why but I am not able to invoke a =
static
> function from
> > within a popupmenu plugin. common is another package =
in
> the same
> invoking a static
shows
> "BEFORE".
> > =20
> error, now it
> > does not show me anything. I have done a project =
clean
> and a full
> directory.
> > =20
> > Tx Praveen.
> > package common;
> > =20
> fileLocation,
> > String fileName) {
> > System.out.println("INSIDE..." + str + " :: " =
> fileName);
> > import =
> > import =
> > =20
> > m_Selection;
> > String location =3D
> > String fileDir =3D =
> location.length()
> "MyFile.txt");
> common.Utils. Is
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DCourier><FONT color=3D#000080 size=3D2>Hi=20
Andrew,</FONT></FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>I made another hello =
world plugin=20
with just the same hierarchy of plugin and other classes and I am able =
to access=20
the plugin static method without doing an export-Package or a =
required-Bundle.=20
</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>In my existing =
project with common,=20
plugin.actions, I added in the exported packages tab and the classpath =
tab. But=20
am still facing the same problem</FONT></DIV>
<DIV><FONT face=3DCourier color=3D#000080 size=3D2>I am not sure what I =
am=20
missing.</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Andrew Niefer" <<A=20
href=3D"mailto:aniefer@ca.ibm.com">aniefer@ca.ibm.com</A>> wrote in =
message=20
<A=20
href=3D"news:eivgh2$spj$1@utils.eclipse.org">news:eivgh2$spj$1@utils.ecli=
pse.org</A>...</DIV>Praveen,<BR>in=20
the OSGi runtime, your plugin.actions bundle can only load classes =
<BR>from=20
bundles that it said it required.<BR>What you need to do is for the =
common=20
bundle to add an Export-Package <BR>for its utils package in its =
manifest.mf=20
file.<BR>Then plugin.actions needs to either Require-Bundle: common, =
or=20
<BR>Import-Package: common.utils in its =
manifest.<BR><BR>-Andrew<BR>Praveen=20
wrote:<BR>> I suspect its because the plugin is in package =
plugin.actions=20
and the <BR>> utils class is in common package. common and plugin =
are at=20
the same <BR>> hierarchy but the execution considers plugin.action =
as the=20
root and <BR>> looks for common.utils inside it.<BR>> =
<BR>> I=20
<BR>>=20
tab but that doesent help. Any other ideas?<BR>> <BR>> =
Thanks=20
Praveen.<BR>> <BR>> "Praveen" <<A=20
;=20
Yes, I apologize for the typo.<BR> > =2 0
<BR>> ~Praveen.<BR>>=20
<BR> > &a mp;nbsp; "David =
Wegener"=20
<<A=20
href=3D"mailto:wegener@cboenospam.com">wegener@cboenospam.com</A><BR>>=
=20
<<A=20
href=3D"mailto:wegener@cboenospam.com">mailto:wegener@cboenospam.com</A>&=
gt;>=20
wrote in =
message<BR> > &a mp;nbsp; <A=20
pse.org</A>...<BR> > &a mp;nbsp; =20
Praveen =
wrote:<BR> > &a mp;nbsp; =20
> I am able to invoke the static method from a regular class=20
as<BR> > &a mp;nbsp; =20
follows.<BR> > &a mp;nbsp; =
> So=20
the eclipse JDK has the class path etc. setup. I=20
suspect<BR> > &a mp;nbsp; its=20
some<BR> > &a mp;nbsp; =
> tweak=20
environment.<BR> > &a mp;nbsp;  =
;=20
>=20
Thanks =
Praveen.<BR> > &a mp;nbsp; =20
>=20
import=20
common.Utils;<BR> > &a mp;nbsp; &nbs=
p;=20
>=20
public class asd=20
{<BR> > &a mp;nbsp; >=20
> public static void main(String[] args)=20
> &a mp;nbsp; =
Utils.writeToFile("A",=20
"C:\\ad",=20
"QWE.txt");<BR> > &a mp;nbsp; =
=20
> =20
}<BR> > &a mp;nbsp; >=20
> "Praveen" <<A=20
href=3D"mailto:jpk4077@hotmail.com">jpk4077@hotmail.com</A><BR>> =
=20
<<A =
href=3D"mailto:jpk4077@hotmail.com">mailto:jpk4077@hotmail.com</A>>=20
<<A=20
;=20
wrote<BR> > &a mp;nbsp; =20
> in message <A=20
pse.org</A>...<BR> > &a mp;nbsp; &nb=
sp;=20
> =20
Hi,<BR> > &a mp;nbsp; =20
> =20
> I am not sure why but I am not able to =
invoke a=20
static<BR> > &a mp;nbsp; =
function=20
from<BR> > &a mp;nbsp; =20
another=20
package in<BR> > &a mp;nbsp; the =
same<BR> > &a mp;nbsp; =20
where I=20
am<BR> > &a mp;nbsp; invoking a=20
static<BR> > &a mp;nbsp; =20
> function of another class Utils. The =
output only=20
shows<BR> > &a mp;nbsp; =20
"BEFORE".<BR> > &a mp;nbsp; =20
> =20
class not=20
found<BR> > &a mp;nbsp; error, =
now=20
it<BR> > &a mp;nbsp; =20
project=20
clean<BR> > &a mp;nbsp; and a=20
full<BR> > &a mp;nbsp; =20
> compile and the class files are present =
in the=20
right<BR> > &a mp;nbsp; =20
directory.<BR> > &a mp;nbsp; =
> =20
> Tx=20
> =20
---------------------------------<BR> > &a mp;n=
bsp; =20
> package=20
common;<BR> > &a mp;nbsp; =20
> =20
> &a mp;nbsp; public static =
void=20
writeToFile(String str,=20
String<BR> > &a mp;nbsp; =20
p;=20
> &a mp;nbsp; &a mp;nb=
sp; =20
String fileName)=20
sp;=20
System.out.println("INSIDE..." + str + " :: "=20
+<BR> > &a mp;nbsp; =20
> &a mp;nbsp; =20
> =20
> =20
bsp; =20
> package=20
plugin.actions;<BR> > &a mp;nbsp; &n=
bsp;=20
> import=20
org.eclipse.core.resources.IContainer;<BR>> &nb=
sp; =20
> import=20
org.eclipse.core.resources.IFile;<BR> > &a mp;n=
bsp; =20
> import=20
; =20
> import=20
org.eclipse.core.resources.IResource;<BR>> &nbs=
p; =20
> import=20
=20
> import=20
org.eclipse.core.runtime.CoreException;<BR>> &n=
bsp; =20
> import=20
org.eclipse.jface.action.IAction;<BR> > &a mp;n=
bsp; =20
> import=20
org.eclipse.jface.viewers.ISelection;<BR>> &nbs=
p; =20
> import=20
=20
> import=20
org.eclipse.ui.IActionDelegate;<BR> > &a mp;nbs=
p; =20
> import=20
org.eclipse.ui.IObjectActionDelegate;<BR>> &nbs=
p; =20
> import=20
org.eclipse.ui.IWorkbenchPart;<BR> > &a mp;nbsp=
; =20
> =20
> public class ConvertAction implements=20
> &a mp;nbsp; public void =
run(IAction=20
action) =
sp;=20
sp; =20
(IStructuredSelection)<BR> > &a mp;nbsp; &=
nbsp; =20
> =20
;=20
sp; =20
Object obj =3D=20
nbsp; =20
sp; =20
sp; &nb sp; =20
obj;<BR> > &a mp;nbsp; =20
sp; &nb sp; =20
=20
sp; &nb sp; =20
bsp;=20
sp; &nb sp; =20
String location =
=3D<BR> > &a mp;nbsp; =20
sp; =20
sp; &nb sp; =20
String fileDir =3D=20
location.substring(0,<BR> > &a mp;nbsp; &n=
bsp;=20
=20
sp; &nb sp; &nb s=
p; =20
1);<BR> > &a mp;nbsp; =20
sp; &nb sp; =20
String str =3D=20
"TEXT";<BR> > &a mp;nbsp; =20
> =20
=20
sp; &nb sp; &nb s=
p;=20
Utils.writeToFile(str,=20
fileDir,<BR> > &a mp;nbsp; =20
"MyFile.txt");<BR> > &a mp;nbsp; &nb=
sp;=20
> =20
nbsp; =20
sp; =20
sp;=20
> &a mp;nbsp; =20
> &a mp;nbsp;=20
> =20
> =20
bsp; =20
I notice that your code doesn't include an import=20
for<BR> > &a mp;nbsp; =20
common.Utils. =
Is<BR> > &a mp;nbsp; =20
this just a cut and paste omission?</BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_017B_01C704C1.600F1970--
Current Time: Wed Jul 16 11:10:53 EDT 2025
Powered by FUDForum. Page generated in 0.08075 seconds
