Home » Eclipse Projects » Eclipse Platform » Eclipse package won't run in Kubuntu 6.10 AMD64
Eclipse package won't run in Kubuntu 6.10 AMD64 [message #309575] Wed, 01 November 2006 03:03 Go to next message
Originally posted by: Xzyx987X.hotmail.com
I installed eclipse from the Ubuntu repository, but I can't seem to get it
to run. The following is the error log produced, which I haven't been able
to figure out myself:
!SESSION 2006-11-01 01:29:12.195
eclipse.buildId=M20060921-0945
java.version=1.5.0_08
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.update.configurator 2006-11-01 01:29:14.083
!MESSAGE Plugin does not have a valid identifier:
plugins/org.eclipse.cdt.source_3.0.1/
!ENTRY org.eclipse.update.configurator 2006-11-01 01:29:14.084
!MESSAGE Plugin does not have a valid version:
!ENTRY org.eclipse.update.configurator 2006-11-01 01:29:15.884
!MESSAGE Could not install bundle plugins/org.eclipse.cdt.source_3.0.1/
Error converting plugin at
/usr/lib/eclipse/plugins/org.eclipse.cdt.source_3.0.1.
!ENTRY org.eclipse.osgi 2 1 2006-11-01 01:29:18.956
!MESSAGE NLS missing message: initializer_error in:
org.eclipse.core.internal.runtime.messages
!MESSAGE NLS missing message: fileInitializer_fileNotFound in:
!MESSAGE NLS missing message: fileInitializer_IOError in:
!MESSAGE NLS missing message: fileInitializer_missingFileName in:
!ENTRY org.eclipse.osgi 4 0 2006-11-01 01:29:19.194
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: memmove
at org.eclipse.swt.internal.gtk.OS.memmove(Native Method)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 67)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 54)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:126)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:433)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Application.java:122)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:75)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:29:19.205
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:29:19.205
!MESSAGE Bundle
update@plugins/org.eclipse.cdt.source.linux.gtk.x86_64_3.0.1/ was not
resolved.
!SUBENTRY 2 org.eclipse.cdt.source.linux.gtk.x86_64 2 0 2006-11-01
01:29:19.205
!MESSAGE Missing host org.eclipse.cdt.source_3.0.1.
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:29:19.206
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:29:19.206
!MESSAGE Bundle
update@plugins/org.eclipse.cdt.source.linux.gtk.x86_64_3.0.1/ [112] was
not resolved.
01:29:19.206
!SESSION 2006-11-01 01:30:12.321
!ENTRY org.eclipse.osgi 2 1 2006-11-01 01:30:14.153
!ENTRY org.eclipse.osgi 4 0 2006-11-01 01:30:14.475
!STACK 1
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:30:14.657
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:30:14.657
!MESSAGE Bundle
resolved.
01:30:14.657
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:30:14.658
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:30:14.658
!MESSAGE Bundle
not resolved.
01:30:14.658
!SESSION 2006-11-01 01:30:33.716
!ENTRY org.eclipse.osgi 2 1 2006-11-01 01:30:35.566
!ENTRY org.eclipse.osgi 2 1 2006-11-01 01:30:35.567
!ENTRY org.eclipse.osgi 4 0 2006-11-01 01:30:35.892
!STACK 1
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:30:36.067
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:30:36.067
!MESSAGE Bundle
resolved.
01:30:36.067
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:30:36.068
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:30:36.068
!MESSAGE Bundle
not resolved.
01:30:36.068
!SESSION 2006-11-01 01:31:15.821
!ENTRY org.eclipse.osgi 2 1 2006-11-01 01:31:18.144
!ENTRY org.eclipse.osgi 2 1 2006-11-01 01:31:18.145
!ENTRY org.eclipse.osgi 4 0 2006-11-01 01:31:18.467
!STACK 1
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:31:18.641
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:31:18.641
!MESSAGE Bundle
resolved.
01:31:18.641
!ENTRY org.eclipse.osgi 2 0 2006-11-01 01:31:18.642
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-11-01 01:31:18.642
!MESSAGE Bundle
not resolved.
01:31:18.642
Re: Eclipse package won't run in Kubuntu 6.10 AMD64 [message #309611 is a reply to message #309575] Thu, 02 November 2006 09:19 Go to previous messageGo to next message
You're the second user that I've seen report this. Does eclipse work for
you if you download it from eclipse.org? If so then this is likely a Ubuntu
packaging issue.
Grant
"Xzyx987X" <Xzyx987X@hotmail.com> wrote in message
news:d5bdf272abc7a6d6e50098c591f5bfd8$1@www.eclipse.org...
> !STACK 1
> at
:122)
> at
java:78)
> at
> at
pLauncher.java:68)
> at
> at
> at
> at
..java:25)
> !MESSAGE Bundle
> resolved.
> 01:29:19.205
> !MESSAGE Bundle
> not resolved.
> 01:29:19.206
> !STACK 1
> at
:122)
> at
java:78)
> at
> at
pLauncher.java:68)
> at
> at
> at
> at
..java:25)
> !MESSAGE Bundle
> resolved.
> 01:30:14.657
> !MESSAGE Bundle
> not resolved.
> 01:30:14.658
> !STACK 1
> at
:122)
> at
java:78)
> at
> at
pLauncher.java:68)
> at
> at
> at
> at
..java:25)
> !MESSAGE Bundle
> resolved.
> 01:30:36.067
> !MESSAGE Bundle
> not resolved.
> 01:30:36.068
> !STACK 1
> at
:122)
> at
java:78)
> at
> at
pLauncher.java:68)
> at
> at
> at
> at
..java:25)
> !MESSAGE Bundle
> resolved.
> 01:31:18.641
> !MESSAGE Bundle
> not resolved.
> 01:31:18.642
Re: Eclipse package won't run in Kubuntu 6.10 AMD64 [message #311878 is a reply to message #309575] Wed, 24 January 2007 14:58 Go to previous message
Originally posted by: fischer.sacred.net
I has this same problem; I tried Grant's suggestion which worked,
as long as the package was owned by me! As soon as I installed
it as root, I got the same error. So it doesn't look like an
ubuntu packaging issue.
I'm running ubuntu Edgy, and I installed the relevant ia32 packages,
which did not seem to help; nor did using the linux32 wrapper.
I'm using the most recent Sun 1.5 package, installed via synaptic.
Linux satyagraha 2.6.17-10-generic #2 SMP Tue Dec 5 21:16:35 UTC 2006 x86_64 GNU/Linux
Hope this helps.
Previous Topic:how to load a class
Next Topic:JFace Databinding obtain modified bean properties
Current Time: Tue Jul 08 08:08:58 EDT 2025
Powered by FUDForum. Page generated in 0.30710 seconds
