Cannot reference a new plug-in? [message #31179] |
Tue, 27 March 2007 07:14  |
Originally posted by: john.chequer.westsussex.gov.uk
I've created a method plug-in in EPF that references the Openup_basic and
base_concepts plug-ins and everything seems to be working fine. I've now
decided to create another plug-in with reference / guidance material in it
that I'd like to keep separated out as it could be used independently by
other plug-ins. However, I can't get it to appear in the list of
"Referenced Plugins" in my original plug-in. Am I missing something
obvious? Or will referencing the original from the new "guidance" plug-in
have the same effect?
John
Re: Cannot reference a new plug-in? [message #31288 is a reply to message #31253] |
Fri, 30 March 2007 04:50  |
Originally posted by: John.Chequer.westsussex.gov.uk
<br><font size=2 face="sans-serif">Thanks Jim,</font>
<br>
<br><font size=2 face="sans-serif">I had created the new plug-in in the
library. I had to change the original plug-in and save it to refresh
its view of the other available plug-ins in the library, so its all working
fine now. Is this a known problem?</font>
<br>
<br><font size=2 face="sans-serif">John</font>
Re: Cannot reference a new plug-in? [message #577369 is a reply to message #31179] |
Thu, 29 March 2007 18:40  |
Hi John,
Have you imported the new guidance plug-in, or created it in the same
library as the original plug-in? It needs to be in the library in order
to be referenced by another plug-in. It's in our library if you can see
the plug-in in the Library view. At that point, you should be able to
double-click on the original plug-in and see the check-box for the new
guidance plug-in.
- Jim
John Chequer wrote:
> and base_concepts plug-ins and everything seems to be working fine.
> I've now decided to create another plug-in with reference / guidance
> material in it that I'd like to keep separated out as it could be used
> independently by other plug-ins. However, I can't get it to appear in
> the list of "Referenced Plugins" in my original plug-in. Am I missing
> something obvious? Or will referencing the original from the new
> "guidance" plug-in have the same effect?
> Thanks
> John
Re: Cannot reference a new plug-in? [message #577394 is a reply to message #31253] |
<br>
<br>
FUDForum. Page generated in 0.04000 seconds
