| changing default auto-build configuration [message #308981] |
Thu, 12 October 2006 01:45  |
hi all,
I want to change default value of auto-build option (Project -> Build
Automatically), when I create new workspace or on first launch of eclipse,
this option is checked bydefault but I want to change this to not checked
as it's default value, where should I make changes for this
Thanks in Advance,
Parag
| Re: changing default auto-build configuration [message #309112 is a reply to message #308981] |
Mon, 16 October 2006 11:56  |
Originally posted by: john.eclipsefaq.org
Assuming you are using the Eclipse SDK, you can do this:
1) Edit the file eclipse/plugins/org.eclipse.sdk/plugin_customization.ini
2) Add the line "org.eclipse.core.resources/description.autobuilding=false".
parag wrote:
> hi all,
> eclipse, this option is checked bydefault but I want to change this to
> not checked as it's default value, where should I make changes for this
> Thanks in Advance,
> Parag
FUDForum. Page generated in 0.03995 seconds
