Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMFT OCL without Eclipse
EMFT OCL without Eclipse [message #31133] Wed, 12 April 2006 16:55 Go to next message
it should be possible to use OCL without running Eclipse as it is with
EMF. I'm building a standalone application and would like to use EMF
OCL. But there are some dependencies on Eclipse - mainly for debugging
and warning outputs. Shouldn't those be removed or at lease encapsulated
in a way that you can use EMFT OCL without Eclipse?
Steffen
Re: EMFT OCL without Eclipse [message #31206 is a reply to message #31133] Wed, 12 April 2006 18:00 Go to previous messageGo to next message
Hi, Steffen,
Your timing is impeccable -- I have just committed
https://bugs.eclipse.org/bugs/show_bug.cgi?id=125628 which enables the
stand-alone deployment that you are looking for.
Note, however, that we will not be producing separate builds for the
stand-alone configuration.
What you will need on your classpath are:
- the org.eclipse.emf.ocl_1.0.0.xxx.jar (as is)
- the org.eclipse.emf.common and org.eclipse.emf.ecore JARs
- the lpgjavaruntime.jar file, which can either be downloaded
from http://sourceforge.net/projects/lpg/ or extracted out of the
OCL plug-in JAR
Look for this in tomorrow's M6a build.
Christian
P.S. -- Sorry, Steffen. I accidentally replied directly to your e-mail on
the first attempt.
Steffen Becker wrote:
> Cheers,
> Steffen
Re: EMFT OCL without Eclipse [message #31484 is a reply to message #31206] Thu, 13 April 2006 15:07 Go to previous message
Oops, sorry,
Actually, today's M6a build does *not* have a stand-alone-deployable OCL
parser/interpreter. I discovered too late that there were still some
dependencies on Eclipse classes that I had not factored out. My tests
succeeded in running without an Eclipse platform *instance* actually
running, but were still using Eclipse classes because my run-time
configuration had the Eclipse plug-in dependencies on the class path.
On the second attempt, I now have the JUnit test suite running with
absolutely no Eclipse platform JARs on the class-path. These changes will
be available in the next build after today's M6a.
Apologies for the confusion.
Christian
Christian W. Damus wrote:
> Hi, Steffen,
> OCL plug-in JAR
> Cheers,
> Christian
> the first attempt.
>> Cheers,
>> Steffen
Re: EMFT OCL without Eclipse [message #574491 is a reply to message #31133] Wed, 12 April 2006 18:00 Go to previous message
Hi, Steffen,
OCL plug-in JAR
Christian
the first attempt.
> Cheers,
> Steffen
Re: EMFT OCL without Eclipse [message #574840 is a reply to message #31206] Thu, 13 April 2006 15:07 Go to previous message
Oops, sorry,
Christian
> Hi, Steffen,
> OCL plug-in JAR
> Cheers,
> Christian
> the first attempt.
>> Cheers,
>> Steffen
Previous Topic:[Announce] EMFT VALIDATION 1.0.0M6a is available
Next Topic:[Announce] EMFT TRANSACTION 1.0.0M6a is available
Current Time: Thu Oct 23 16:09:45 EDT 2025
Powered by FUDForum. Page generated in 0.05786 seconds
