How to change node figure at runtime? [message #31013] |
Sun, 27 August 2006 06:14  |
Originally posted by: dzhpingbo.sohu.com
I want to change the figure of notation view at runtime.
I want to fulfill this function: at runtime workbench, when I choose the svg
figure that I provide through the choose file dialog, the node I select in
editor will change to that svg figure, how can I implement this?
Re: How to change node figure at runtime? [message #34253 is a reply to message #34155] |
Wed, 30 August 2006 08:56  |
Originally posted by: 5d5.mail.ru
Hello!
By the way you may use org.eclipse.gmf.dev.insider plugin from devtools
section in cvs to make a snapshot of diagram editor; there will be a
tree of all figures, edit parts and edit policies so you may check
whether your figure was actually added even if it's not visible.
Dmitry Stadnik wrote:
> Hello!
> When you add figure with image to the plate figure it should be
> revalidated and repainted; do you add image figure? Are you sure that
> this image figure is not hidden behind some other figure?
> dzh wrote:
>> Thank you very much:) according to your method, I can change the
>> figure at runtime now, but everytime I had to reopen the editor and
>> then it will change...
>> I had tried to use myNodeEditPart.refresh() method to refresh the
>> views, but it does not work..
>> How can I refresh the figure without reopening the editor?
>> "Dmitry Stadnik" <5d5@mail.ru> ??????:ecuq72$4fp$1@utils.eclipse.org...
>>> Hello!
>>> In graph definition model specify some plate for the node (just
>>> Figure should do) and set StackLayout for it. In runtime after
>>> selecting svg and creating ImageFigure add it to the plate figure.
>>>> the svg figure that I provide through the choose file dialog, the
>>>> node I select in editor will change to that svg figure, how can I
>>>> implement this?
FUDForum. Page generated in 0.11444 seconds
