Home » Eclipse Projects » Eclipse Platform » writing JUnit tests to verify extension points?
writing JUnit tests to verify extension points? [message #307737] Tue, 29 August 2006 20:33 Go to next message
Originally posted by: liam.morley.baesystems.com
I've just created an extension point, and now I'd like to write a JUnit test
to verify that it works. I thought I would create a class that extends my
extension point and then verify that I can see it using the method described
http://wiki.eclipse.org/index.php/FAQ_How_do_I_find_all_the_ plug-ins_that_contribute_to_my_extension_point%3F.
The problem is, if I do that, my JUnit test will depend on this dummy
project. Is there any way I can extend my extension point programmatically?
Or do I have to create a new project and extend the extension point there?
Liam Morley
Re: writing JUnit tests to verify extension points? [message #307738 is a reply to message #307737] Tue, 29 August 2006 20:58 Go to previous message
Originally posted by: wharley.bea.com
"Liam Morley" <liam.morley@baesystems.com> wrote in message
news:ed2mce$e89$1@utils.eclipse.org...
> test to verify that it works. I thought I would create a class that
> extends my extension point and then verify that I can see it using the
> method described at
> programmatically? Or do I have to create a new project and extend the
Best way is to have one plug-in project that is your intended functionality,
and another plug-in project that extends your extension point and contains
JUnit tests. In fact you may want to simply put all your JUnit tests in
that second project, so that you don't burden your shipping plug-in code
with test code. That's how Eclipse itself mostly works: if you look in CVS,
you'll see lots of org.eclipse.foo.tests plug-ins, that test the
corresponding org.eclipse.foo plug-ins.
One reason for this is that there is a longstanding bug in Eclipse
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=109137) that means that if
you launch a debug Eclipse instance on a plug-in project, projects within
the debug instance won't be able to see the classes in the project. That
is, the code for the project being launched will be *executed* in the debug
instance, but it won't be *visible* to other projects within the debug
instance. That in turn means that your test dummy project would not be able
to see the code that it is supposed to extend.
Previous Topic:toolbar contribution of global actions
Next Topic:need help to understand Action , ContributionItem, MenuManger etc
Current Time: Mon Sep 01 02:38:48 EDT 2025
Powered by FUDForum. Page generated in 0.03978 seconds
